ARP studs.. washers/no washers? Cant get a straight answer
  • Kozworth
    • May 2011
    • 1339
    I ordered some arp m20 studs a few months back. Putting them in, I remembered that some guys said reuse the oem washers. I looked on IE and it says the kit comes with washers, bolts, and studs. I contacted a few places and got moved to a guy (forget who or the site he was from). He said the kit should come with it and its necessary.
    My kit was brand new and just has the torx nuts with a washerbase connected, no separate washers and the studs. I called IE and they said that running no washers is normal.
    I have also googled that you can use oem washers.
    So what is the verdict? I know IE has been around forever so I am just trying to confirm what works best.
  • whodwho
    • Jun 2008
    • 1547
    Should of come with washers, I would run the stock ones if not. Keep an eye on the stud length and make sure if has full threads for the nut.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      The point of the washers is both to be a load spreader and to move the friction from the aluminum head casting to steel. You need the washers.
        • 37833
        IE did not used to include the ARP washers. I was the one who got them to do it!
        You can order ARP washers or just run the OEM washers.
        Grover Beach, California
        BimmerHeads.com
          • 34844
          the stock washers will work fine. they're not exactly a wear item.
          I would not use steel bolts on an aluminum head without washers.
          • Kozworth
            • May 2011
            • 1339
            Ok Guys that's what I was thinking and just wanted to confirm it since I got first hand conflicting answers
            • 93supercoupe
              • Oct 2012
              • 84
              I had the same issue. I just re-used the stockers. It listed as them being apart of the package but i didnt get any.
              I had 2-3 threads still above the deck, like they werent bottomed out, but they were, as they were all the same height, and i had cleaned the wholes. Anyone else see this issue? SETA motor
              • quickjones
                • Jul 2011
                • 20
                I contacted IE about the stud kits a couple of weeks ago, and they told me to reuse the stock washers, but most of my engine bay was in the trunk of my car when I bought it, so I honestly don't know if all of them are there, but they told me they would sell me a set.
                If more E30 guys went to the track vs hard parking on steelies at Kroger's that could probably happen.
                • SkiFree
                  • Jun 2011
                  • 2766
                  Matt's pretty persuasive, as of about 2 months ago the IE kits started to receive washers. If anyone didn't receive washers after that point then please email/pm me directly. As for any tech. ?'s feel free to email/pm.
                  ADAMS Autosport
