Nevermind
Please delete
Tags: None
My understanding is that the o2 sensor wouldn't make the car completely cut out, just run like crap. Not only that, I don't know if it'd make sense that the car runs totally fine with the diagnostic cap if it's a bad o2 sensor.
Let me know if my assumptions are wrong.Comment
When the engine cuts out does the tachometer needle drive towards zero when the transmission is in gear and the car moving? That could mean a DME shutdown, in which case you should also see the CEL. Or it could mean a problem with timing data from the CPS. But if the tachometer doesn't react I might suspect leakage in the cap involving pin 1, which goes to the ignition coil.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Wouldn't hurt to spray the pins/sockets in the diagnostic cap with contact cleaner...
This may help too:
5-Speed Swapped
M30B35 Swapped
MegaSquirt MS3X
1987 325i Lachssilber Sedan
260k OEM Automatic Daily Baby
Doesnt the cap on the diagnostic plug have jumpers in it ?Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
1989 325i Lachssilber Sedan
5-Speed Swapped
M30B35 Swapped
MegaSquirt MS3X
I've searched through manuals, trouble shooting guides and still have found nothing useful.Last edited by freethebikes; 05-14-2013, 10:39 PM.Comment
