What Should an M20 Rebuild Cost?
  • thedmkshow
    • Apr 2013
    • 9
    Ok, so I bought my E30. Engine runs beautifully and exhaust sings but to be certain and confident, I want to rebuild my engine this year professionally.
    What are your thoughts on what that should cost?
    OR would I be better off waiting and doing an S14 or M50 motor swap?
    Danny Kuntz
    incultur3, LLC
    d.kuntz14@me.com
    8058079554
  • MT325is
    • May 2012
    • 1103
    Do some research.. There is a lot of information on this forum.
    1. Do you know how much an s14 costs?
    2. M50 swap is done by a lot of people and considered an easier swap. (Some people like I for example don't see the point of an m50 there isn't much of a difference in power... But it's is a dohc)
    3. A rebuild kit with everything except crank from bavarianauto runs $1400... For every seal, valve, piston, etc... If you want it done professionally done then add idk how much for labor on top..
    You can pick up an s52 for about $2500 ... So idk if it's even worth it.
    But if your engine runs good why rebuild it... Save up for a s5x swap or anything you might wanna decide.
    1989 BMW 325is (SOLD)
    1992 BMW 325IC (SOLD)
    1991 BMW 318IS (STOLEN!)
    2017 BMW M2 (WEEKEND WARRIOR)
    1989 BMW 325IC (PROJECT(
    2002 FORD ESCAPE (DAILY)
    • ButtJuice
      • Dec 2009
      • 2609
      Just my .02, but the difference between an m20 or m50 is totally different than an s14. Especially in price difference. If you can afford an s14, why would you even consider keeping your m20?
      But in attempt to answer your question, it all depends on who is going to rebuild your motor and how far you want to take it. Some simple head work can range around $1,000 or a full head rebuild can get up to $3,000. That doesn't even include the block.
      This info is just from my experience.
      If it were me, I'd rather spend the money on an m50, m52, s50, or s52 swap.
      (albeit I'm currently fixing my m20 cylinder head, I just can't afford a swap)
      1991 318is - Sold
      1986 325 - Sold
      Instagram - Lamoursum
      • ButtJuice
        • Dec 2009
        • 2609
        Originally posted by MT325is
        Do some research
        Power difference isn't great, but the maintenance of an m50 compared to an m20 is great.
        hydraulic lifters = no valve adjustments
        no timing belt
        you don't have to tension belts n shit.
        1991 318is - Sold
        1986 325 - Sold
        • Holland
          • Nov 2008
          • 7212
          Yeah you aren't doing an S14 swap. If you have to ask how much, it's too expensive.
          Originally posted by DEV0 E30
          • XW70
            • 290
            This. Pretty sure you could have the head rebuilt on M20 for the cost of a the S14 timing chain tensioners.
            Delphin '87 325i Vert
            • george graves
              • 19998
              Street car? On the street, an s14 will be s-l-o-w-e-r.....
              Awesome motor - but....worst in it's class for HP/dollar.
              Someone should do a ruff HP/$$$ for swaps for each motor - that is - you'll pay X amounts of bucks for X amount of HP.
              Originally posted by Matt-B
                • 34839
                why on earth would you spend $1400 on a rebuild kit? I guess you get new pistons, but they're going to be crummy made in china pot metal. I'd rather have reconditioned stock pistons and an extra $800 for a cam.
                  The amount of wear in the engine is a major factor is the cost of a rebuild. If the cylinders are worn out of tolerance an overbore and new pistons are required that alone is about $1000 in parts and machine work. A head rebuild can be a few hundred or over $1000, depending on how much wear there is. So until the engine is torn down and inspected one can't predict the actual cost.
                  • Vtec?lol
                    • Dec 2009
                    • 3278
                    .... M50's aren't worth the time or effort. Not unless it's being built for boost.
                    s50 or better cuz
                    • FasterSoonerNow
                      • Jan 2013
                      • 66
                      You can definitely pick up and S52 for around the cost of a professional M20 rebuild, but who knows when it will need some major work. I've seen so many threads where people are comparing rebuilds to buying a motor out of some salvage car. They aren't comparable, it's apples and oranges.
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        Although I'm going the stroker turbo route, I have considered an M5x swap because of maintenance. It's all about your preference, bud.
                        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                        2012 Passat TDI - DD Duty
                        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                        • Cabriolet
                          • 9620
                          the s14 is crap in traffic and as a DD. but heaven in the hills
                          but here's the kicker. you can't afford this swap. it's about 15k+ and so not worth it. (hp/$)
                          7k for the s14, 1k for trans, then add on new DS,diff,clutch,wire harness, etc... then rebuild costs on the S14 can be as much as 3500 (for a light refresh)... all to get the same power as a built M20 just makes this a bad idea.
                          To do a refresh on an M20 costs $1000 for bare min and 2500 to do it right. but to get more power our will run you about 5k to do it right.
                          an S52 swap should run you 5k and it will out preform the M20.
                          Much wow
                          I hate 4 doors
                            • 34839
                            yet again.. people compare a junkyard $5k S5x swap to a brand new, built M20. Not a valid comparison. of course the junkyard motor costs relatively less..
                            • Cabriolet
                              • 9620
                              s52s here are now selling for 1500, so im figuring in new HG, and head lightly refreshed.
                              Don't get me wrong. i love a built M20, the sound, the torque, the period correctness. but the only drawback is hp/$
                              Much wow
                              I hate 4 doors
