What tempature is your m20 running at?
  • e34_spangler
    • Dec 2012
    • 311
    My gauge is showing that the car only gets up to a quarter which seems pretty cold to me when most cars usally run at half? Is that bad good or just a gauge being stupid
    Sent from my SCH-I535 using Tapatalk 2
  • ButtJuice
    • Dec 2009
    • 2609
    It's your temperature gauge, it's not working properly. Check the nut on the back or swap in another one.
    If that doesn't work, replace your thermostat.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
    • dnguyen1963
      • Nov 2011
      • 2649
      Most likely, You have the wrong t-stat in your car.
      • e34_spangler
        • Dec 2012
        • 311
        Well I got the t stat from bmw
        • SkiFree
          • Jun 2011
          • 2766
          Well... BMW sells more than one temp. t-stat. Which temp. did you buy?
          ADAMS Autosport
          • offsetmotorwerks
            • Apr 2013
            • 27
            There are 71*, 75*, 80* (most common). I use a 71 and it runs at the first mark.
            • e34_spangler
              • Dec 2012
              • 311
              Oh ok well they gave me what they told me I should put in.. didn't really think about there being different ones I just wanted the part being lazy but yeah runs at the first mark which is fine with me its not getting hot! But I wanted to make sure that's ok for the engine
              • dnguyen1963
                • Nov 2011
                • 2649
                Living in PA is going to be tough in the winter time with your current t-stat. I would suggest that you replace it with a 80C stat. It will take longer to heat up the car with a 70C stat. Your car will not be efficient running that cold, but it will not cause any damage.
                • e34_spangler
                  • Dec 2012
                  • 311
                  Ok sounds good
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Actually a 70 and 80 will warm up at exactly the same pace since the engine doesnt know or care what the set point is of a closed tstat. The 70 will just open a bit sooner.
                    The M20 should have an 80
                    Alice the Time Capsule
                    • e34_spangler
                      • Dec 2012
                      • 311
                      ok thanks for the info guys!
