Goetze HG leaking after ~15K miles
  • lcoleman
    • Jan 2009
    • 331
    So, I know this is a common problem with the VR gaskets, but I'm wondering if anyone else has had a similar experience.
    New head gasket, head was skimmed, new bolts, etc. Plenty of copper spray, block was clean. It didn't start leaking until maybe 10K miles after the change. Right now, it runs great, no oil/coolant mixing, but oil is pissing down the side of the block in the front as well as at the rear. Might have a bit of seepage from the cam and rear main, but it's definitely originating mostly at the HG. It leaves two big spots everywhere I park.
    Anyone else had this happen with a "quality" gasket?
    Is there anything to do other than yet another head gasket/skim head/new bolts job?
    Is there anything else I can do to prevent this next time? I thought I had all the bases covered.
    • 34847
    new bolts, torqued properly?
    that's a really common M20 leak area. I doubt there are very many M20s that don't leak there..
    • Rc 415
      • Jun 2011
      • 723
      Sure it's not the rocker shaft plugs? I've had them leak and thought it was for sure the headgasket
      1987 Delphin 325IS
      LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
      Build Thread
      1993 alpine 2 325IC
      •Ground control coilovers•16" BBS RS• momo woodgrain
      • lcoleman
        • Jan 2009
        • 331
        New bolts, torqued properly, though I can't say I got exactly 90 degrees each time. I would say close enough. I know it's normal to leak, but this is severe and developed pretty quickly.
        I already swapped the rocker shaft plugs. Maybe I should try some OE ones instead of whatever aftermarket brand I got, though. Still, it made no difference. The block is soaked with oil, while the head is (relatively) clean and dry.
        Thanks.
          • 34847
          yeah, you don't have to be exact with a TTY bolt - you just need to reach the flat part of the stress/strain curve.
          • Cabriolet
            • 9620
            what brand of bolts?
            Much wow
            I hate 4 doors
            • timninja
              • Feb 2011
              • 302
              Actually,i used the same brand and dead serious its been 11k and im having coolant issues because i believe he head gasket is already broken.
              • lcoleman
                • Jan 2009
                • 331
                Looks like OE, assuming ECS doesn't have a typo. They're cheaper than the VR ones.
                http://www.ecstuning.com/BMW-E30-325...h/11121726478/
                Maybe it's just life with an m20, but they can't have done this new. Part of me thinks I should live with the leaks, run it 'til it dies, and cram a b35 in it after.
                • AwakenNoMore
                  • Dec 2010
                  • 1291
                  This thread is stressing me out, I just finished rebuilding my engine with a Goatze head gasket. Its bad enough my coolant gauge is a troll, now this thread.
                  1991 325i - "Scambles" The Daily Driven lightly modded.
                  1988 Mazda RX-7 TII "Mako" The Free Dorito
                  bacon by Jared Laabs, on Flickr
                  • bmwstudent
                    • Sep 2011
                    • 1364
                    I went with a head gasket and new bolts from bmw, I've only got about 1k on my total rebuild. I'll be keeping an eye on it
                      • 34847
                      most likely the gasket hasn't failed, the more likely explanation is you didn't bleed it properly, or it wasn't installed properly (preparation is key).
                        • 34847
                        I doubt it's the brand of bolts - there's nothing wrong with VR headbolts either.
                        • Cabriolet
                          • 9620
                          I've had one build where a few of the VR bolts stretched.
                          but if people what security go ARP and be done with it. those bad boys work very well.
                          Much wow
                          I hate 4 doors
                            • 34847
                            uh, they're supposed to stretch. that's how TTY works. :p
                            perhaps they were turned too far or the threads were not totally clean.
                            ARP are totally unnecessary on anything but a turbo build. For the most part, TTY are a better design.
                            you know all those giant skyscrapers, buildings and bridges? the bolts are all TTY..
                            • EatsHondas
                              • Sep 2012
                              • 404
                              Mine acted the same way, ironically right after I freshened up a new head and threw it on. I pulled the cluster, removed the grounding nut for the fuel and coolant temp gauges, cleaned them with contact cleaner and a toothbrush, and put 'em both back on. Tight. Super steady coolant gauge now. I'd definitely try that if you haven't already.
                              What is your gauge acting like? Mine would show normal temp, and then it would wiggle constantly and jump into the red zone without warning. Sometimes tapping the cluster would make it behave, sometimes it wouldn't.
                              1989 325i Lachssilber Sedan
                              5-Speed Swapped
                              M30B35 Swapped
                              MegaSquirt MS3X
                              1987 325i Lachssilber Sedan
                              260k OEM Automatic Daily Baby
