2.7 Rebuild info
  • Jordan
    • 12913
    #31
    You are going to need to bore the block out to 85mm to make a 2.8L
    https://mtechniqueabs.com/
    • Gus
      • Jan 2004
      • 285
      #32
      sorry i would have mentioned it, but thought it was obvious. im just throwing ideas around and trying to find more info as in NZ not many strokers are around that have been build recently (ie people knowing what goes into them). may just stick with 2.5 for the project and do something to get more power later.
      JUNGL3
      1990 "333i" Sport
      • chuck90m3
        • 568
        #33
        Originally posted by Jordan
        Also, food for thought.
        S54B32: (8,000 rpm limiter)
        Stroke 91 mm
        Rod length 139mm
        Rod ratio 1.53
        so with the E46 M3 crank what rods and pistons do you need?
        im new to the M20 game so im just looking at my options.
        i have a 91 325i and i also have a full 88 528e engine.
        what combo would work the best(crank,rods,pistons) with out major machine work, and what would be the CR of the chosen setup?
        thanks in advance for the help.
        "A casual stroll through the lunatic asylum shows that faith alone does not prove anything."
        Friedrich Nietzsche
        • JJGBMW323
          • Oct 2005
          • 36
          #34
          Correct. My stroker 1989 325i block is a 2.8 liter using Metric Mechanic pistons and its been bored out to 85 mm. The previous owner used the "I" rods and the eta crank. The eta crank is 81 mm. I am replacing the eta
          crank with a knife edged 524td crank.
          I have since sourced an 95 m3 s50 crank. So some day I am going to use
          the s50 rods with this to build even a bigger stroker. But for the time being
          I want to run the 2.8 M20.
          Head 1990 325i ported and polished - +1 valves
          -325i cam reground to 272
          Block 1989 325i 2.5 liter bored 85mm - forged MM "I" pistons
          Crank 1986 524 td -Knife edged 524 td crank.
          Flywheel -11 pounds lightened 325i flyweel.
          Oil pump -524td oil pump.
          79 323i
          • madjurgen
            • May 2005
            • 1203
            #35
            Whats the reasonable limit for boring? 85mm? 86mm?
            Does the m52b28 crank drop right in like the s50 or eta one?
            As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
            You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
            • gstuning
              • 833
              #36
              There are two simple ways of doing a 2.7i
              First and cheaper and simpler,
              84mm block
              Eta crank
              rods
              pistons
              731 head (323i/320i)
              325i fuel injection and exhaust
              Second,
              84mm block
              eta crank
              I or eta rods
              customs pistons with compression of choice to suit the rods picked
              887 (325i) head
              325i fuel injection.
              If you have a ETA engine, get a 325i fuel injection and a 731 head and your done.
              If you have a 325i engine , get custom pistons and your done,
              Those are the choices.
              2.7 with 731head is ideal for those with ETA motors,
              731 head are EXTREMELY comon in europe , they have double valve springs, high cam and 1mm smaller valves then 325i heads, but they do have a better squish zone so potentially equal when looking for about 190-200hp out of your eta.
              If you live in europe, get a eta engine and a 320i engine, 325i FPR and 325i injectors, and your done, all can be had for small amounts,
              I fail to see why strokers are complicated
              Gunni
              @ Prodrive / Aston Martin Racing
              • SpecM
                • Oct 2005
                • 4531
                #37
                -Cuz you don't live in America. We don't get a 731 head and our people are too cheap for custom pistons.
                1989 cirrisblau-metallic 325i
                • gstuning
                  • 833
                  #38
                  731 heads aren´t exactly exspensive you know,
                  it only takes registering on the e30zone.co.uk forum til get one.
                  Gunni
                  • silversleeper
                    • Mar 2005
                    • 2032
                    #39
                    so, with my us 325i, i can just slap a nice set of high cr forged pistons and call it a day?
                    Claus Luthe is my hero.
                    • SpecM
                      • Oct 2005
                      • 4531
                      #40
                      -Of course. But then, you wouldn't have a stroker.
