2.7 Rebuild info
  • Gus
    • Jan 2004
    • 285
    2.7 Rebuild info
    search does nothing for me, so i have some q's
    i am looking to build a 2.7 out of my 2.5 and a incorrectly built 2.7 (e pistons, 320 intake manifold/TB etc). i am hoping to take the crank and rods out without separating (as to not have to buy new con rod bolts) and put the 2.5 pistons on (after the skirt being machined, as they are out a pre FL) and rebuild the engine. what will i need to replace? headgasket set, head bolts, oil seals are what i have so far....what am i missing?
    any genuinely helpful info will be much appreciated
    JUNGL3
    1990 "333i" Sport
    • 34839
    I would keep your i rods.. in any case this will require custom pistons, about $800 for a set.
    • Gus
      • Jan 2004
      • 285
      i rods are 135mm...too long. dont want to get custom pistons as $$ and not really needed for my application
      JUNGL3
      1990 "333i" Sport
      • Jordan
        • 12911
        Can you say really really low compression and next to no gains?
        https://mtechniqueabs.com/
        • Gus
          • Jan 2004
          • 285
          with 325i pistons? and e crank and rods?
          JUNGL3
          1990 "333i" Sport
          • Jordan
            • 12911
            325i pistons, eta rods and crank won't work.
              • 34839
              you can't use stock pistons. The point of the longer rods is for a better rod/stroke ratio, since you need custom pistons anyway.
              • Gus
                • Jan 2004
                • 285
                so you're saying this Total BMW article is completely wrong?
                JUNGL3
                1990 "333i" Sport
                • Jordan
                  • 12911
                  Budget strokers are teh suck.
                  There are 2 ways to do things.
                  Right.
                  Again.
                  • madjurgen
                    • May 2005
                    • 1203
                    Whats the rod ratio for:
                    i rods and i crank
                    i rods and eta crank
                    i rods and s50b30US crank?
                    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                    • Kilomph
                      • Oct 2004
                      • 599
                      Gus, check out E30Tech.com, there's a lot of 2.7i information there.
                      • Jordan
                        • 12911
                        i rods and i crank
                        1.82
                        1.67
                        1.56
                        i rods and s52b32US crank?
                        1.51
                        i rods 135mm
                        e rods 130mm
                        i crank stroke 75mm
                        e crank stroke 81mm
                        s50 crank stroke 86.4mm
                        S52 crank stroke 89.6mm
                        The consensus amongst engine manufacturers is that a ratio of 1.50 is the lowest acceptable rod ratio for a street motor. Realistically, rod ratios between 1.65 - 1.80 are ideal.
                        • madjurgen
                          • May 2005
                          • 1203
                          Rod ratio is directly related to revability or the willingness to rev, correct? I know other things contribute as well, but all else equal...thats what controls it correct? Doesnt bode well for a 3.0L stroker using i rods and S50b30US crank.
                          On an offnote, how long are the S50b30US rods?
                            • 34839
                            the other option is the M52B28 crank (84mm stroke) e rods (130mm) and i pistons.. but this gives you a pretty low r/s. I've been thinking it over and I'd rather spend the money on the correct pistons so I can use the longer rods and not sacrifice my revs. I want more torque, but I love the way the 2.5 runs from 4k+.
                            • Jordan
                              • 12911
                              M20B25
                              M50B25
                              S50B30
                              S52B32
                              S70B56
                              All use 135mm rods. Might be more, but those I know off the top of my head.
                              You are correct. The lower the rod ratio, the less willing to rev up and high a engine is going to be.
