2.7 Rebuild info
  • Borat
    • Jan 2005
    • 494
    Gus, did you miss the bit in that article about the 325i pistons and e rods sitting down too low? They will sit 1.5mm too low in the block.
    • madjurgen
      • May 2005
      • 1203
      Originally posted by nando
      I want more torque, but I love the way the 2.5 runs from 4k+.
      This is exactly how I feel. So you plan on using the M52B28 crank with e rods and custom pistons? Sorry to sound stupid but whats r/s? What cr do you plan on having?
      So even a stock e36 M3 has a rod ratio of 1.51-1.56. Seems pretty low.
      As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
      You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
        • 34839
        no, I'll either do the 2.7 eta crank or M52B28 with i rods (e are 130mm vs the 135mm for the i). as far as compression, I'm not sure yet, but no higher than 9.5:1 (we only get 92 octane around here).
        as far as the M3 engine, remember that professional BMW engineers designed it to do what it does, I don't exactly have millions in R&D budget so I try to stick to the basics. :)
        • Jordan
          • 12911
          Also, food for thought.
          S54B32: (8,000 rpm limiter)
          Stroke 91 mm
          Rod length 139mm
          Rod ratio 1.53
          https://mtechniqueabs.com/
          • Gus
            • Jan 2004
            • 285
            i did read the part in the article about the pistons sitting low in the bores...i also read the part about machining that height off the top of the block and having an adjustable cam pulley to compensate the timing
            sorry, but i fail to see why using the 325i pistons is a bad thing...they would match the head, and have a high(ish) compression ratio. is there something obvious i am missing?
            JUNGL3
            1990 "333i" Sport
            • Jordan
              • 12911
              Decking the block 1.5mm is a really bad idea.
              • PeaveyBassist
                • Sep 2004
                • 3511
                Why is that Jordan?
                Will
                RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                Welcome e30 (brilliantrot '90 325is) 12/23/06
                DaveCN = Old Man
                My signature picture was taken by ME! Not by anyone else!
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • Gus
                  • Jan 2004
                  • 285
                  as above...strength/cooling issues?
                  JUNGL3
                  1990 "333i" Sport
                    • 34839
                    Originally posted by PeaveyBassist
                    Why is that Jordan?
                    Will
                    cam timing will be quite a bit off, among other possible issues. you could get a custom cam sprocket made to fix that but ehh.. may as well just spend the extra dough on forged pistons at that point.
                    • SpecM
                      • Oct 2005
                      • 4531
                      -But you can just adjust the factory cam gear to compensate, right?
                      1989 cirrisblau-metallic 325i
                        • 34839
                        if you mean moving the belt one tooth at a time, sure, but that's not going to give you the range of adjustment neccesary to set cam timing correctly.
                        • e30bimmerdude
                          • 272
                          why not just save yourself some time and money.....and go F/I with a eta bottom, 731 head..325i ecu, T/B, and intake mani.....good power at only 6-8psi and a boat load of torque... not to mention the 7.9:1 comp which is a bit low, but maited with a good sized turbo= alot o fun!
                            • 37828
                            Originally posted by Jordan
                            Budget strokers are teh suck.
                            This is me calling your bluff
                            Mine is far from teh suck
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • Jordan
                              • 12911
                              It has a big old snail connected to it, as such it is disqualified.
                              • Gus
                                • Jan 2004
                                • 285
                                well i cant see any reason not to deck block...an adjustable cam gear would surely be far less expensive than forged pistons...anyway anyone got any answers to my original questions? how many bits need to be replaced? more of a general rebuild question than a stroker one.
                                on another tangent, how well would a eta bottom end and 885 (325i) head handle boost?
                                if i did want forged pistons, could i just order oversized enough to make a 2.8 and then just replace the eta pistons and whack my 325i head on? how would i communicate the piston shape to the piston builder?
                                JUNGL3
                                1990 "333i" Sport
