Vibration. Hate to ask but...
  • TobyB
    • 5296
    Here's an odd thought- did you loosen and pretension the driveshaft after it was installed?
    If the driveshaft's pushing on the back of the transmission, it MIGHT be letting the
    engine rock front- to back...
    Long shot, I know, but very easy to check- just loosen the center nut...
    t
    • dogsbark26
      • Nov 2008
      • 533
      Do I just have Dual Mass Flywheel on the brain or could failure of that cause your issue? Is there any change when you disengage the clutch?
      • mr ilia
        • May 2011
        • 582
        Not sure if OP has seen this reply.
        Originally posted by JohnH
        I have been suffering similar symptoms to the OP, vibration increasing with revs (plus seemingly running a bit rich). Jlevie got me thinking, so I checked the plugs and although all of them showed some sootiness one of them was worse. I replaced the 415 green top injectors with the original 715 blue tops, and guess what. Its now running as smooth as silk. Worth a try.
        • dwight
          • Dec 2012
          • 550
          how about arcing spark wires?
          • Anony Mouse
            • Feb 2011
            • 180
            Symptoms were identical before and after injector swap, replacing plugs was step one when this came up. Just did Fuel filter and FPR no change. What really kills me on this is the car runs great. No loss of power, no overheat, no smoke, no ill effects other than feeling like a gotdaym tractor.
            Elaborate?
            *sigpic
            • dogsbark26
              • Nov 2008
              • 533
              Originally posted by Anony Mouse
              Elaborate?
              Look at plug wires with engine running in the dark (at night). You will be able to see arcing from the wires to ground if wires are leaking. Probably do not want to touch a leaking wire!
              • Anony Mouse
                • Feb 2011
                • 180
                Theres no lasting adverse effect from pulling plug wires while she's running? Sorry if thats a dumb question I'm not much a motor guy yet.
                *sigpic
                • dogsbark26
                  • Nov 2008
                  • 533
                  Probably won't kill you unless you have a bad heart already (or you jump into the path of a moving truck) but why risk it?
                  Or did you mean damage to the car?
                  No. It won't hurt the car any.
                  • Anony Mouse
                    • Feb 2011
                    • 180
                    I just had a thought on this, what are the odds of it being clutch/flywheel related. She's driveable right now and the clutch doesn't feel out of sorts but could there be flywheel issues with this sort of symptom?
                    *sigpic
