89 325i Looking to modify maybe stroker? or m50?
  • Benito_URGOVKURUPTS
    • Apr 2013
    • 25
    Havent had the car long. engine seems "tired" Trans Shifts straight. however always does seem like its " jamming in to gear" by jamming i mean being forced in? if that makes any sense...
    Anyways looking to fresh up to reliable dd status with a bit more power response with out spending too much. any suggestions?
    What do i need to create a 2.7i stroker? or should i moves o m50 non vanos or?
    as stated im not looking for the cheapest way as to i do not want to compromise reliability for peroformance or vice versa
    include links to parts plz or anything else deem helpful:):p
  • SmokeE30
    • 1730
    A 2.7i won't be that much more powerful than a good running m20b25 so I would say a 24v swap because you can get stock motor reliability out of it and better gas mileage too without breaking the bank plus the. U can use a zf trans and get rid of your jamming into gear problem at the same time
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
      • Apr 2013
      • 25
      ive been looking around and cant find a decent priced m50 so if the 2.7 isnt worth the time how could i refresh my engine.
      where would you suggest i start
      • digger
        • Nov 2005
        • 6171
        get a different car with healthy engine and trans
        • redlightpete
          • Mar 2012
          • 265
          It depends on whether you want to build an m20 or not. You can't just go buy a big m20 stroker at your local junk yard. A bigger m20 can make good power. Search for people's dyno results. I think the comments about 2.7i motors not making much power are referring to eta motors with the stock i head swap, not a high compression cammed 2.7.
          • digger
            • Nov 2005
            • 6171
            a high compression cammed 2.7L is a good thing but will cost more than 99% of people want to to pay. there is no cheap NA hp in the M20.
