Best spark plug for e30?
  • AlexHale
    • Nov 2012
    • 230
    Any preference Bosch vs ngk vs denzo? Copper core vs 4 tip blood diamond plated blinders? Seriously, which is the best plug on a internally stick motor with MAF and 19lbs( if that matters, didn't know if it'd change heat range...idk). Thanks for any relies.
    Originally Posted by Exodus
    He also kept asking why someone local didn't just go to the guys house and break his kneecaps, as they would do in Romania. He couldn't understand how us Americans are so laid back about shit like this.
  • dnguyen1963
    • Nov 2011
    • 2651
    Really old topic! Do us a favor and use the search function.
    • AlexHale
      • Nov 2012
      • 230
      Dude I know! I just didn't know if using a maf and bigger injectors will make a difference, will it?
      • digger
        • Nov 2005
        • 6176
        use NGK over bosch no fancy shit though, and on M20 with upper CR BPR6ES which is one range cooler.
        • QUKBMER
          • 8178
          Your using a standard ngk spark plug part #BPR6ES or CR BPR6ES?
          • AlexHale
            • Nov 2012
            • 230
            CR=compression ratio correct?
            • digger
              • Nov 2005
              • 6176
              the CR means compression ratio.
              BPR6ES is the p/n for ngk but only for a higher compression engine the stock ngk is fine for stock engine
              • AlexHale
                • Nov 2012
                • 230
                That's the answer I was looking for, thanks digger
                • FLG
                  • Sep 2011
                  • 3165
                  Dont get anything fancy, over the years ive found on stock engines (not just e30's but in general) the OEM plug is really the best, period. On a built/forced induction motor, go with something better.
                  More so on an engine that burns out, before taking it apart my Charger was leaking oil past the valves ruining spark plugs, i found the cheap 1$ champion plugs not only lasted longer but she was happier, and when it came time to change i was only out a few bucks.
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  • mccor023
                    • Jul 2011
                    • 683
                    Just my .02 running similar setup (maf/ 19 lb) I ran the new Bosch W8LcR+ and fouled them out in 6months flooded the head. Searched harder and found the old style W8LCR no plus and Ive been smooth ever since.
                    I'm might have the pt#'s wrong an OG can correct them as Im sure they know what Im talking about.
                    I love that people ask stupid questions so I dont have.
                    • AlexHale
                      • Nov 2012
                      • 230
                      I too am running Bosch w8LCR+ and had one break, which caused a huge miss, and want to move one, btw are you running miller mccor?
                      • digger
                        • Nov 2005
                        • 6176
                        id probably consider champion plugs for the whipper snipper but not much else...... NGK always worked better than bosch for me
                        • mccor023
                          • Jul 2011
                          • 683
                          Yes.
                          • digger
                            • Nov 2005
                            • 6176
                            they changed the p/n for the B25 bosch plugs at one point W8LCR and then WR8LC or something along those lines.....was apparently still the same plug or newer version but 100% compatible they said
                              • 34844
                              I use the BPR6ES too, as a side benefit to working well, they are cheap as dirt and i can go to any small redneck autoparts store in town and find them.
                              For a stock engine the equivalent would be BPR5ES
