M20 Cams
  • AlexHale
    • Nov 2012
    • 230
    M20 Cams
    I know this is very unR3vlimited, probably why I can't find any damn information on this subject, but I'm looking for a cam that will give my car a rough, aggressive idel. I'm sure everyone is familiar with Comp Cams Thumpr series. I'm looking for a cam such as that, would a 272, 284, or what give me the lumpiest, mean sounding idle? Obviously performance is important, but I really want that sound.
    Originally Posted by Exodus
    He also kept asking why someone local didn't just go to the guys house and break his kneecaps, as they would do in Romania. He couldn't understand how us Americans are so laid back about shit like this.
  • acolella76
    • 2950
    Poke a hole in your intake boot.
    -Alex
    • Killacortes
      • 1937
      Lol ^
      r3v does not fuck around. First you get banned, then they shoot you
      • meengreene30
        • Mar 2012
        • 369
        I run a 272 which isn't lumpy at all. a 280/274 might be what you're looking for. look into Bimmerheads, they'll set you up with the info and degree you want.
        • acolella76
          • 2950
          A cam with a proper tune really shouldn't have a lumpy idle at all
          -Alex
          • AlexHale
            • Nov 2012
            • 230
            Does no one want a thumps idle but me...?
            • acolella76
              • 2950
              I do. I love the sound of a big block V8 with a lumpy idle, but on an otherwise stock (or mild) M20 it is more often a sign of a poorly running engine than a strong one.
              -Alex
              • AlexHale
                • Nov 2012
                • 230
                I mean yeah, very true, so 272 or something wilder?
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  Why? Put a V8 in your E30 if you want lumpy idle.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    Or better yet, put a Harley Davison engine in there.
                    • dnguyen1963
                      • Nov 2011
                      • 2651
                      Davidson
                      • digger
                        • Nov 2005
                        • 6170
                        a schrick 288 has enough thump for ya? generally there are mechanical problems fitting this cams in M20 running stock pistons (the piston and valves touch). the sound comes from low idle speed to so the slower you get it to run at idle the more it sounds like that. Some of these big miscle cars idle at 600-700rpm or so
                        have a look on youtube plenty videos
                        • AlexHale
                          • Nov 2012
                          • 230
                          Mmm ptv contact, sounds like a fun time. I assume the idle on an M20 is not easily adjusted, if it even can? I haven't found much on adjusting idle, just people complaining about theirs.
                          • LJ851
                            • 7919
                            Put a 4 barrel carb on a 320/6 manifold and cam up !
                            Motronic get it's panties all bunched up with any reasonable amount of overlap.
                            Also, to run a bunch of overlap you will need way more compression than the B25 has stock.
                            Lorin
                            The M30 is God's engine.
                            • AlexHale
                              • Nov 2012
                              • 230
                              I may just pm about this lj, I've seen this rare bird, but where and how is it to find? The Manifold from a early m20 right? Any advantages in power?
