M20 Cams
  • digger
    • Nov 2005
    • 6198
    even the stock b25 manifold has all runners feeding from the same source so there is alot of cross talking between cylinders.
    any cam that has decent overlap creating reversion you'd want a standalone system to get full control over the idle fuel, timing and any PWM system. a good set of stainless headers amplifies sound to
    • slow325isedan
      • Mar 2013
      • 113
      A big lumpy cam with no proper headwork will not make any more power then it did before, maybe a little but its not worth the money just for a good sounding idle, pull the head and get a port and do heavier valve springs with new valve guides and seats, then you can run as big of a cam as you want and it will actually make power!
      Build Thread
      • AlexHale
        • Nov 2012
        • 230
        Is back cutting the valves a good idea?
        Originally Posted by Exodus
        He also kept asking why someone local didn't just go to the guys house and break his kneecaps, as they would do in Romania. He couldn't understand how us Americans are so laid back about shit like this.
        • LJ851
          • 7919
          Originally posted by AlexHale
          I may just pm about this lj, I've seen this rare bird, but where and how is it to find? The Manifold from a early m20 right? Any advantages in power?
          There is one sitting at my buddies house in Roswell right now. For sale.
          Lorin
          The M30 is God's engine.
          • LJ851
            • 7919
            You forgot the most important aspect, more compression, a lot more.
            Lorin
            • AlexHale
              • Nov 2012
              • 230
              adding an adjustable cam gear, and retarding the timing add to a lower idle, correct?
                • 34844
                retarding the timing will lose low end torque, and with a stock motor, not gain a lot in the top end.
                changing cam timing won't change the idle speed anyway.
                I would stick to a 272, even a 284/272 is a little too much for the stock engine, partially because the CR isn't high enough, and also because of likely piston/valve interference issues with the intake valves.
                • AlexHale
                  • Nov 2012
                  • 230
                  Are new valve springs, heavier beehive etc, nessciary or really recommended when switching to a 272?
                  • AlexHale
                    • Nov 2012
                    • 230
                    Mystery-E , bimmer heads said, I believe if memory is correct, oversize eccentrics are not nessciary, but ie where I'll order from says they are, anyone with expiernce on it?
                      • 34844
                      new stock springs work fine for a schrick 272 or 284/272.
                      with a 288, you definitely need different springs.
                      I would not use stock, 20+ year old, 200,000 mile springs with an upgraded cam.
                        • 34844
                        that depends on if it's a regrind or not.
                        • AlexHale
                          • Nov 2012
                          • 230
                          If a regrind then yes?
                            • 34844
                            yes
                            • AlexHale
                              • Nov 2012
                              • 230
                              Ah thanks man!
