Skipping a beat in full pull through second
  • Zreberlcoe
    • 1555
    Whenever I start a full throttle pull from the low rpm in second gear to almost red line around 2500 rpm I feel a small jerk like a cylinder isn't firing and again sometimes somewhere between 3800 and 5000 rpm. I first thought it was the jerkiness of going over a bump while in high rpm but I noticed its consistency. Any ideas?
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
  • 603Racing
    • Dec 2010
    • 612
    Fuel starvation? Weak spark causing missfire under load?
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
    • Zreberlcoe
      • 1555
      How could I test these two things?
      BMW
      • dnguyen1963
        • Nov 2011
        • 2651
        1. Tee in a pressure gauge.
        2. Watch this video
        • Larzzz
          • Jan 2013
          • 531
          I think i have the same thing in my 86 325es. Mines in 1st 2nd and third gear, well actually all gears. it has a jerking feeling. Like not getting fuel or something. Mines between 2K and 4K rpm. Could it be a bad fuel filter?? i already relplaced spark plugs, air filter and some fuel hoses.
          1991 318i Slicktop - Sold
          1991 325ix - Sold
          1997 Estoril M3 Coupe - Sold
          1986 325es - RIP
          1997 328is - Sold
          1995 Avus M3
          instagram @MattLarzz
          //M42 GOON-SQUAD
          http://www.r3vlimited.com/board/showthread.php?t=281596
          • Cabriolet
            • 9620
            your Kps is going bad
            http://www.pelicanparts.com/cgi-bin/...2520%2520%2520
            Much wow
            I hate 4 doors
            • Larzzz
              • Jan 2013
              • 531
              What exactly is that?
              1991 325ix - Sold
              1986 325es - RIP
              1997 328is - Sold
              1995 Avus M3
              //M42 GOON-SQUAD
              • LJ851
                • 7919
                Crank Postion Sensor and it's a good guess.
                Lorin
                The M30 is God's engine.
                • FLG
                  • Sep 2011
                  • 3165
                  Think he meant cps and it very well could be.
                  See if ohms to spec, won't be definitive test though. I personally would replace it on these cars with an oem unit from the dealer, don't get aftermarket they're junk. After 20 years they are somewhat a time bomb
                  Sent from my SCH-I545 using Tapatalk 2
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  • Larzzz
                    • Jan 2013
                    • 531
                    I work at a BMW dealership as a detailer/lot porter and get discounts in parts. Tomorrow ill go to parts and have them look it up! Thanks!
                    1991 325ix - Sold
                    1986 325es - RIP
                    1997 328is - Sold
                    1995 Avus M3
                    //M42 GOON-SQUAD
                    • Zreberlcoe
                      • 1555
                      The previous owner put in new spark plug wires. I'm thinking fuel filter is where I should start because who knows the last time that was changed.
                      BMW
                      • Cabriolet
                        • 9620
                        no, e30s dont have CPSs - this forum misuses it
                        CPS = Cam position sensor
                        KPS = Crank position sensor
                        Much wow
                        I hate 4 doors
                        • TobyB
                          • 5297
                          or your flapper door's not flapping correctly...
                          ohm out your AFM and see if there are irregularities in its resistance.
                          t
