2.7i swap drivability issues
    • 34839
    Originally posted by Gary Horneck
    Here's the table I have -
    Temperature Minimum Resistance Maximum Resistance Tolerance
    0°C 32°F 5.0k 6.2k 10%
    20°C 68°F 2.2k 2.8k 10%
    30°C 86°F 1.5k 1.9k 10%
    The IAT does affect timing, so...
    but not during startup, cranking advance is a fixed value.
    • Swanny
      • Mar 2012
      • 2834
      Originally posted by nando
      I'm not sure that IAT affects starting - usually coolant is the only factor since airflow during cranking is minimal.
      so, the question is - are you getting fuel pressure during cranking? is the CLT sensor working?
      The sensor by the thermostat or on the radiator?
      Swanny!
      SUCKERS.
      • Gary Horneck
        • May 2011
        • 435
        I was attempting to address the issue in the video. Looked like good pressure in the video. So starting hot could be another issue. But, the engine loaded up after running is possible. You have two sensors?
        2011 335i/1995 Mercedes C220 (rallyx)
        • Swanny
          • Mar 2012
          • 2834
          Coolant temp sensor correct?
          Swanny!
          SUCKERS.
          • Swanny
            • Mar 2012
            • 2834
            Looks like the restart issue is based off a warm engine.
            Nando, could you confirm the sensor you mentioned? Not familiar with the CLT name.
            Swanny!
            SUCKERS.
              • 34839
              coolant. the one by the thermostat (usually blue). the thing in the radiator is a coolant temp switch for the electric fan.
              • Swanny
                • Mar 2012
                • 2834
                Cool, after dinner its time to simulate an open and closed signal and see what happens. Thanks!
                Swanny!
                SUCKERS.
                • Swanny
                  • Mar 2012
                  • 2834
                  Unplugged the coolant temp sensor and that made the idle insanely low and loopy. Tried to jumper the connector but no change. Plugged it back on the sensor and it was back to it's original idle.
                  Swanny!
                  SUCKERS.
                  • Gary Horneck
                    • May 2011
                    • 435
                    Yeah, did not think it was a coolant temp sensor. What's coming out the tailpipe? Is it overly rich?
                    • Swanny
                      • Mar 2012
                      • 2834
                      It seems a bit rich but nothing outstanding. Unfortunately didn't get a chance to check the distributor and rotor though....curious about spark intensity as well.
                      Decided to try to tackle the tach issue with no luck of course. Waste of a damn day!
                      Swanny!
                      SUCKERS.
                      • Swanny
                        • Mar 2012
                        • 2834
                        Sitting in the airport right now, would love some other things to get my brother to try to test pr at least get his mechanic to pick up where I left off.
                        Swanny!
                        SUCKERS.
                        • efficient
                          • Feb 2012
                          • 3312
                          ever figure out what was wrong?
                          • Swanny
                            • Mar 2012
                            • 2834
                            My brother got his hands on another AFM and 173 ECU but I'm sure he hasn't gotten around to trying them out. Unfortunately the sensor housing on the afm is cracked and not too sure it's a complete working unit. As soon as I can bother him enough to get his car to run properly I'll update!
                            The next thing would be to check all the electrical (cap, rotor, grounds, plugs, yadda yadda) but I think he's going to take it to a shop to have them throw a couple hours into it.
                            Swanny!
                            SUCKERS.
