Oil leak question
  • DoneRightBimmer
    • May 2012
    • 158
    Oil leak question
    So im trying to track down my oil leak on my 93 e30 m20 cabrio. The oil is leaking out between the trans shield and bell housing of the trans, it isn't dripping down from above because i just replaced head gasket and valve cover gasket ext. It leaks when at rest slow dripping which forms a baseball sized oil spot in a 24 hour period. So i believe it is either the Rear main seal or the rear half of the oil pan gasket with is covered by the trans shield. I read somewhere before that at rest the oil level isn't high enough to leak out of the Rear main seal is this true? If so that leaves the oil pan gasket as the culprit. Im going to remove the trans shield covering the oil pan next time i visit the car and hopefully ill be able to see the cause.
    Appreciate any help/ opinions.
  • vpilarrt
    • Jun 2006
    • 2096
    That may be true, however you could be throwing oil out the seal into the bellhousing while driving and then when you park it drains out the weep hole.
    • bmwstudent
      • Sep 2011
      • 1364
      Excellent point
      • jeffnhiscars
        • Jun 2011
        • 6011
        dye may not help given the closeness of your suspects but its worth the $6 to try.
        Alice the Time Capsule
        • DoneRightBimmer
          • May 2012
          • 158
          That is true hmm hopefully I can see the cause when I remove the cover
          • DoneRightBimmer
            • May 2012
            • 158
            Update for anyone leaking from same location. Ended up being brake fluid from my slave cylinder, it was a slow leak and didn't notice any loss of brake fluid or clutch issues until a month later, when i had the car parked for a snow storm and the clutch went to the floor and had zero pressure and I noticed my brake fluid went down. Replaced Slave cylinder and no more leaks. Dirt and grime made the fluid appear to be motor oil.
            Thanks for everyone's help on the Forum
