Weird oil leak
  • John Beton
    • May 2012
    • 8
    Weird oil leak
    Hello people,
    ik had this weird thing yesterday. Just bought some new rims (bbs RZ 378, yummie yummie) and wanted to put them on the car yesterday.
    I ususally dont lift the front of the car by putting the jack underneath the oil pan. But yesterday i did so. And after being lifted for about 2 minutes I spotted a little puddle of oil.
    Normally my car does leak a bit but like 5 drips in 1 day. Yesterday with the jack underneath it went very very quick. Once i put the car back on the ground the leaking stopped (or normalised to almost nothing).
    I am wondering if you guys have ever experienced this with an m20. I fear that my oil pan doesn't seal good and once having a load on it a minor opening appears or something.
    Does someone know something about this?
    Thanks guys
    BTW, is it really not done to jack an e30 m20 by its oil pan?
  • E30Gus
    • Jun 2008
    • 781
    NO!!!!! Check for cracks in the pan then slap yourself!
    • SpecM
      • Oct 2005
      • 4531
      the oil leak isn't all that weird
      you just cracked your oil pan
      1989 cirrisblau-metallic 325i
      • SmokeE30
        • 1730
        Agreed you put a crack in the pan or just made an existing one bigger.
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
        • z122643
          • Aug 2011
          • 286
          not to be harsh... but you're in idiot!
          [/SIGPIC]"we are so totally screwed!"
          • 603Racing
            • Dec 2010
            • 612
            Where's the :fail: smiley?
            Check oil pan for cracks. Aluminum oil pan can barely keep itself from leaking under normal conditions.
            90 325i DD/Track
            03 Durango 5.9
            Originally posted by e30mpg
            It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
            • htown318is
              • Feb 2012
              • 301
              if you really gotta do that, at least put a long 2x4 between the jack and pan lol.
              but coulda used subframe with the 2x4.. or each side on proper points.. or anything else!! lol!!!
              bad luck friend.
              • digger
                • Nov 2005
                • 6206
                i usually jack via the side mirror at the front or tailpipe at the back
