Lots of water vapor in exhaust
  • djork
    • Apr 2013
    • 33
    This morning was a little chilly, and there was a lot of condensation in my exhaust. While going down the road with other cars, I noticed I was putting off way more vapor than anybody.
    Most other cars appeared to be warmed up and not making any condensation.
    It's 58 degrees F out now with 55% humidity, and I drove a few minutes to lunch and back, and it's still puffing water vapor. It even steams a little when it's shut off.
    Here it is while idling: http://www.youtube.com/watch?v=MI8P-2fs810
    Here it is after stopping the engine: http://www.youtube.com/watch?v=v5dv0udkTIk
    There's no oil in my coolant reservoir, or water in my oil.
    I recently changed the timing belt, and did what was probably a shitty job bleeding the cooling system. I am afraid that maybe a bubble in the cooling system has lead to a hot spot in the block and a crack. Is this possible without any other symptoms like cross-contamination in my oil and coolant?
    "What? Something about road noise? I can't hear you..."
  • ME30W
    • Feb 2012
    • 811
    Likely just the cold weather. If you start losing coolant, then you definitely have a HG/Head problem. If your coolant level is not decreasing, then no issue with a cracked head/block.
    Interested to see if others have any information...
    I like cats.
    • dnguyen1963
      • Nov 2011
      • 2651
      That's nothing. If you are burning coolant, it would be white thick smoke.
      • TobyB
        • 5297
        Taste it.
        If it's sweet, you're fucked.
        If it just tastes like water that ran through an engine, it's all good.
        The E30 dumps more water out it's exhaust than any other car I've ever had.
        t
        • timmyr77
          • Jun 2012
          • 353
          Mine does the same thing. As long as your not losing coolent your good
          • AwakenNoMore
            • Dec 2010
            • 1291
            ^ This.
            OP, Your being a bit paranoid I think. Given the temperature and humidity numbers you gave it sounds fine. Just keep an eye on your temps and coolant level.
            1991 325i - "Scambles" The Daily Driven lightly modded.
            1988 Mazda RX-7 TII "Mako" The Free Dorito
            bacon by Jared Laabs, on Flickr
