Sad to see this m20 Like This
  • KIRIEIW
    • Dec 2012
    • 3385
    My friend wanted to takle a timing belt change on his own, in the process of all the hoses off and trying to find TDC he gave up and brought it to a shop to install the already purchased parts. He drops it off and they install it and call after saying spark plug in cylinder #4 blew out… They put a heliocoil and say theres no compression in it and say they need to remove the head because theres a bent valve, to find this:
    went to a reconditioning head shop and he said theres nothing to do if a spark plug hole os cracked but buy a new head...i told my friend he needs to order a new head now and a new piston, engine has 250k on it but its a good body with minimal rust spots, only the battery tray suffers a bit. Worth fixing is the main question here or should he get another m20/ or part out, maybe sell the car completely. If he used that piston I'm pretty sure the compression would blow a hole in it right? Trying to figure out the cheapest way possible to get this body on the road again.
    CAR RAN 100% perfect before the timing belt change was tackled….
    http://www.flickr.com/photos/kirieiw/10586436314/
    http://www.flickr.com/photos/kirieiw...n/photostream/
    http://www.flickr.com/photos/kirieiw...ream/lightbox/
    1992 e34 Touring- S50 Swap
    1992 325i-S50 Swap (SOLD)
    1991
  • mr.vang
    • 4371
    Buy an used m20. There plenty around since everyone is going 24v
    • KIRIEIW
      • Dec 2012
      • 3385
      whats the likely hood of the crankshaft being bent from the pressure the piston put on it while hitting the valve?
      1991
      • digger
        • Nov 2005
        • 6037
        piston will act like a fuse and disintegrate before you hurt the crank
        • RobertC
          • Dec 2010
          • 127
          Did your freind want change the timing belt due to it running terrible or did the car run fine before taking it apart??
          If it ran fine then is the shop responsible for the busted valve and engine replacement?
          Just curious as the description of events is not entirely clear as to what happened.
          www.facebook.com/E30motorwerks
          • Cabriolet
            • 9620
            i have an extra set of I pistons laying around if you want that. but u may need a lot more
            Much wow
            I hate 4 doors
            • KIRIEIW
              • Dec 2012
              • 3385
              ran great which leads me to believe it was also the shops fault… the car was purchased off a old lady who had it sitting in he garage for 6 years before he bought it so he was in the process to putting in the hoses and fluids and he decided to do the timing belt at the same time.
              1991
              • AndrewBird
                The Mad Scientist
                • 11898
                Yeah, what caused the valve to hit the piston? If the engine was running fine before hand, it sounds like the mechanic had the timing off when they fired it up.
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  that would be really great man! Im hoping a new head with valves and a piston is all it needs, thats what my eyes are telling me anyway.
                  1991
                  • digger
                    • Nov 2005
                    • 6037
                    get a replacement engine. it will be way cheaper
                    • SmokeE30
                      • 1730
                      So the shop you took it to fucked it up. Tell them to buy you another motor and bring it somewhere that knows what their doing to install it.
                      Shawn @ Bimmerbuddies
                      Bimmerbuddies LLC
                      717-388-1256
                      2971a Roundtop Rd, Middletown PA 17057
                      bimmerbuddiesllc@gmail.com
                      • KIRIEIW
                        • Dec 2012
                        • 3385
                        I'm really leaning toward that answer too, i told my friend now the same. I feel that they might use the excuse "you brought it too us not running so it was like that before" when it defiantly wasn't, just had all the hoses off and some belts, including the old timing belt on it. IT WAS RUNNING JUST NEEDED TO CHANGE THE TIMING BELT TO AVOID THIS SORT OF DAMAGE! My friend must have messed the timing up, brought it to the shop to install the new belt and they never checked the timing and just threw on the new belt. I don't see how else it could have happened...
                        1991
                        • Cabriolet
                          • 9620
                          KIRIEIW, tell your peeps i do it for $120 labor TB/WP and i even provide the parts at cost if they want to do it that way. an M20 TB is retardedly easy. idk how so many shops screw it up
                          Much wow
                          I hate 4 doors
                          • KIRIEIW
                            • Dec 2012
                            • 3385
                            I told him, let's see what his response is. I told him that shop was crappy, I usually do this stuff with my dad (if it was my car) he's an airline mechanic.
                            1991
