How to tighten crankshaft bolt on m20b25 w/o $50 tool.
  • nickmcc92
    • Dec 2012
    • 442
    So, I accidentally loosened the crankshaft bolt after I adjusted my valves. Left the wrench on there and turned on the car without knowing. Now every time I turn on my car while cold it makes a chirping sound, but goes away warm. So, does anyone have any special ways to tighten the bolt without purchasing the $50 tool from PelicanAuto?
    Thanks.
  • Cabriolet
    • 9620
    Bed frame and drill
    IMG_0906 by DonBerger1, on Flickr
    Much wow
    I hate 4 doors
    • nickmcc92
      • Dec 2012
      • 442
      That's smart. Thanks man.
      • EyExR
        • Jan 2011
        • 959
        Ha! Nice. I'm going to fab up something as well. I'm building an engine and don't like the idea of sticking a block of wood into the crank...
        My 325iX DIY Threads:
        Front Wheel Bearing Replacement
        325iX Rear Subframe Bushings and MUCH more w/pics!
        325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
        • htown318is
          • Feb 2012
          • 301
          may be problem if engine is still in car due to clearance issues.
          I used a decent sized, maybe 12-15 inch chain wrench, torque wrench and some red loctite to get it over 200 easily. good enough for me though.
          made the same mistake you did.
          • Gregs///M
            • Mar 2012
            • 2459
            Bed frame and drill
            LOL Eric, was not expecting that.
            That $50 tool really really makes things easier, especially if you have multiple BMW's.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • Cabriolet
              • 9620
              i've used this 10 times. every time it's worked perfectly and it was free.
              Much wow
              I hate 4 doors
              • mpowerful
                • Jul 2013
                • 1273
                We made same thing at shop out of a piece of flat iron bar. Works great. No BMW tool needed.
                • nickmcc92
                  • Dec 2012
                  • 442
                  I was also reading that Harbor Freight has a tool like the this.
                  Haven't checked, just what I heard.
                  • TobyB
                    • 5298
                    I made one, too- pretty easy with a holesaw and a drill press...
                    t
                    • IveGotIssues666
                      • Oct 2006
                      • 517
                      If the car is a 5 speed just leave the car in gear (5th gear) wheels on the ground. I've removed and tightened crank bolts that way plenty of times. If its an Auto you'll either need a counter holding tool or impact gun
                      Jared
                      • nickmcc92
                        • Dec 2012
                        • 442
                        Wish it was but it's auto.
                        • Jaxx_
                          • Dec 2009
                          • 1880
                          I was going to suggest park... I'm a bit tired.
                          There is usually a place where you can stick a flathead screw driver on the flexplate, and hold it that way. It is a little hard to hold the rotating assembly in an auto.
