worth the efforts
  • ikonwun
    • Apr 2012
    • 374
    worth the efforts
    Hello all.
    I have a 88 super ETA. I have focused on my cars maintenance and looks. I haven't really done anything to help the performance for the M20 really.
    the car came with
    1.1 motronic,153 dme, eta cam, springs, throttle body, intake manifold and 885 head stock. I have read it has a lower compression ratio
    I was wondering if it was worth the work to install IS cam, springs, intake manifold, throttle body, 1.3 motronic wiring and 173 DME.
    This is my daily it has lots of torque and very FUN TO DRIVE. but more power would be fun. Im not really planning on boosting it.
    thoughts? feed back?
    anyone done this to seta?
  • McGyver
    • 4636
    you should already have all of the i/is head stuff. If you truly have a 325es, and not just the sticker, they came with the regular eta 2.7l bottom end and the i/is 885 head. what made it special from any other etas is that the head is from an i, so you have a higher revlimiter and more power than a regular eta.
    ...i would suggest boost or an engine swap.
    • Cabriolet
      • 9620
      yes it is very common and not that hard of a swap
      Much wow
      I hate 4 doors
      • ikonwun
        • Apr 2012
        • 374
        I have a 5300 rev limiter. and I have checked I have 885 casting head.
        I have read I have an eta cam and springs intake manifold and TB... . I don't know how to confirm this.
        I really don't want boost. want a simple street car that I daily.
        • ikonwun
          • Apr 2012
          • 374
          looking for really hp changes? DYNO graphs.?
          Im just asking if it worth the effort if Im not planning on boosting it later.
          • Cabriolet
            • 9620
            yes, there are gains but i dont feel like searching for the dyno numbers.
            it can be done for about 1k so for the money it's a really good swap. it pulls a little harder than a b25 engine. but to be honest i couldnt tell the difference when riding in the swapped cars because all the other chassis modifications that the guys had done.
            Much wow
            I hate 4 doors
            • ikonwun
              • Apr 2012
              • 374
              cool Ill be doing for way less than a grand. so I think ill do it dyno my car before on works dyno and post before and after dyno number
              • Cabriolet
                • 9620
                not possible.
                get the BMW head gasket and bolts. new water pump. new timing belt. new hoses, new fuel line. new gaskets. bmw coolant. oil cooler.
                and how many miles are on the lower? you many need to rebuild that. bc that will make more of a difference than upgrading, if you have more than 250k-mi
                Much wow
                I hate 4 doors
                • ikonwun
                  • Apr 2012
                  • 374
                  not pulling the head just replacing the intake, tb, cam, springs , wiring and DME.
                  new water pump /timing belt hoses /(every bit of the fuel system replaced /lots of maintenance work has gone into this car already
                  Please READ my build thread...
                  I will do the valve stem seals when I have the springs off. the bottom end is good have awesome compression. but unknown mileage
                  • Cabriolet
                    • 9620
                    did some readying, looks like you are more of a whore for wheels than i am. lol
                    ah so you are gonna pull all of it while you have a compressor in holding the valves up.
                    how do you plan to get the cam out with the engine still in the bay?
                    after refreshing 7 M20s idk if i would go this route but budgets dictate what you can and cannot do
                    Much wow
                    I hate 4 doors
                    • digger
                      • Nov 2005
                      • 6215
                      i would pull the head and refresh it, that alone improves things
                      • ikonwun
                        • Apr 2012
                        • 374
                        I'm not trying to make a big project out of this..
                        that is money out in parts and this is my only daily right now wife wouldn't like if I took it off the road for no real reason.
                        I don't understand? maybe I'm in over my head. (no pun intended) why can the cam be pull while the motors in the car?
                        • Cabriolet
                          • 9620
                          maybe you can get it out by taking the front out. but that would be a lot of work
                          IMG_5875 by Eric Berger, on Flickr
                          Much wow
                          I hate 4 doors
                          • ikonwun
                            • Apr 2012
                            • 374
                            yeah Im a whore.. but have found some wheels im sticking with..
                            yes air holding up the valves.
                            not really wanting to call this a refresh just a update. a refresh will be later on.
                            I don't understand why ths cam coming out is so hard? i guess im s noob and will find out.
                            • ikonwun
                              • Apr 2012
                              • 374
                              well I see now... like old v8's cam gets fed into the motor?
