885 i Vs 885 Seta, STRAIT ANSWER PLEASE.
  • delamaize
    • Nov 2013
    • 1452
    ok, so I have done a lot of reading, and I am still thoroughly confused.
    I have a complete 885 Seta head. with SEVEN cam Journals. I have been reading that I need to drill oil passages, some say I don't, some people are saying the 885 seta are not real 885. so WTF IS IT?!?!?!:hitler:
    I assume that a 885 is a 885, and all I need to do to have any kind of preformance is to change out the valve springs and cam.
    Dumpster Fire Pilot
  • wilholl
    • May 2012
    • 518
    if you're head has a 7 journal cam, then that is correct...
    Just swap the cam and valve springs.
    however to get the "i" performance you will still need to change the intake manifold, throttle body, airflow sensor, injectors and ECU
    my Seta was the same way
    1988 325 non-letter Seta "Bronzit"
    1991 325ic "Laguna Green" (Sold)
    1993 325i "Laguna Green/Silver" (Sold)
    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
    2000 528i Titansilber/gray m-sport
    2000 528i Titansilber/black m-sport(sold)
    2001 525i Anthracite m-sport(sold)
    2013 750i Black/Black m-sport "Beast"
    • TurboJake
      • 3780
      If your 885 has 7 journals. You're good to go.
      It's only if it has 4 that you need to drill.
      Plus what wilholl said.
      Leave Me Transaction Feedback
      • delamaize
        • Nov 2013
        • 1452
        thanks guys....
        Dumpster Fire Pilot
        • jmc1590
          • Jul 2008
          • 112
          A little clarity as I recently went down this path....
          All 885 heads (i & Seta) have 7 cam journals. Some of the 885 heads for Seta have all 7 journals drilled. Some do not.
          To use a 7 journal cam, if I remember correctly, all the journals on the intake side need to have oiling passages. The #4 journal on the exhaust side does as well.
          On the 4 journal variant, #'s 1,3,5,7 have oiling holes on the intake side. #'s 3 & 5 have the oil holes on the exhaust side.
          Hope this helps...
          • wilholl
            • May 2012
            • 518
            Yes and to and confusion... one of my 885 (Seta) heads had a 4 bearing cam in it. So, 3 of the journals were not drilled at all.
            • SmokeE30
              • 1730
              thats how some of the early production SETA heads were but it seems most of the later ones have all 7 journals drilled.
              Shawn @ Bimmerbuddies
              Bimmerbuddies LLC
              717-388-1256
              2971a Roundtop Rd, Middletown PA 17057
              bimmerbuddiesllc@gmail.com
              • delamaize
                • Nov 2013
                • 1452
                is there a casting year where the cutting corners stop and the drill them all?
                Dumpster Fire Pilot
                • wilholl
                  • May 2012
                  • 518
                  It wasn't that they cut corners, it was because they started using a 7 bearing cam instead of 4 bearing earlier cams.
                  The 4 bearing cam was originally used to reduce efficiency robbing friction as the eta engine was all about economy.
                  At least that is what I have been lead to believe based on my reading comprehension.
