1988 325is running poorly
  • ArdaMK2
    • Jan 2009
    • 559
    So i went to school, drove fine. Going back home, started fine but idled rough and drove like its a subaru Do you guys know what may have caused my car to run improper, i mean it sounds like its running on 2 cylinders. I tried my best to diagnose it but i have not a clue.
    Just replaced plugs last week, Spark is present in all cylinders. Im leaning towards a fuel issue. Could it be fuel relay/filter/pump? I would appreciate if you guys chimed in with some answers. Thanks in advance.
    Follow me on instagram @arda.e30
    What plugs did you use? The best choice now is NGK ZGR5A's.
    • ArdaMK2
      • Jan 2009
      • 559
      I got the Boschs wrc8
      • Cabriolet
        • 9620
        blown headgasket. do a compression test. i bet you will fine 2 <100psi.
        ask me how i know
        i've blown 2 head gaskets and every time they make the M20 sound like a subi engine.
        Much wow
        I hate 4 doors
        • ArdaMK2
          • Jan 2009
          • 559
          Hmm. Kinda sounds the same. Will do a compression test when i get home later. How hard is it to replace hg for these engines?
          • Cabriolet
            • 9620
            it takes me 4 hours if i have a refinished head to put on. otherwise 3days bc of machining time.
            Much wow
            I hate 4 doors
            • ArdaMK2
              • Jan 2009
              • 559
              Ok. Do i HAVE to get the head rebuilt?
              • Cabriolet
                • 9620
                you will need to get it machined and pressure tested. and new oil seals. at this time i always regrind the seats. and check valve lash.
                Much wow
                I hate 4 doors
                • ArdaMK2
                  • Jan 2009
                  • 559
                  Might as well get it rebuilt then. Ok i will post up some compression numbers when i get home
                  • ArdaMK2
                    • Jan 2009
                    • 559
                    I dont think its the HG
                    Compression numbers : 150 130 150 125 123 125
                    No coolant/oil mixture in the tank either.
                    I forgot to mention there is a loss of power also.
                    • ArdaMK2
                      • Jan 2009
                      • 559
                      Found the problem. Vacuum leak. Theres a two vacuum lines from the throttle body missing. Can anyone tell me where it goes. Must have fallen off
                      • ArdaMK2
                        • Jan 2009
                        • 559
                        The red circle shows the same lines. Are they suppose to connect to something? Sorry im a noob
                        • uturn
                          • Dec 2010
                          • 1001
                          You must have really did a number to get those to fly off!
                          The one line on the left is to the ICV, unless you're refering to the one in front of it that goes to your valve cover. The two on the right combine and go to the brake booster.
                          • ArdaMK2
                            • Jan 2009
                            • 559
                            It could have been the vibration from the exhaust, musta shimmied off :p
                            I was referring to the ones on the right. Looks like I have to take a trip to the jy
