Fuel smell in/around engine bay (solved)
  • Sea Aych
    • Apr 2013
    • 767
    SOLVED thanks guys
    Coming into a problem that's popped up pretty randomly in the past two days. I sealed a small leak near the tank on the weekend, and then this week (i think the two are unrelated), i started smelling raw fuel on the front end after sharp turns or when pulling up to a stop. Those are the times i notice it, but i'm sure that's just because the wind isn't blowing the fumes away at that point.
    No fuel around the injectors that i can see, but i did find some fuel (greenish for premium) on the frame near the driver's side wheel well (see pic below). as well as on the passenger side engine mount (much less, but it's there).
    It's negative eight billion degrees in Toronto right now so i'm just looking for possible sources before i find a warm place to jump under the car myself.
    TIA!
    1988 Atlantisblau Euro/Japanese 325i Cabrio
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited - gone
    My 17,000km Big NA National Parks trip!
    That point is right about where the soft lines to the engine connect to the hard lines under the body. Either could be leaking.
    • Sea Aych
      • Apr 2013
      • 767
      Thanks, that's what i was looking for!
      what gauge of rubber hose is used at this point?
        You need 8mm (or 5/16") fuel injection hose. Ordinary fuel hose can't take the pressure.
        • Sea Aych
          • Apr 2013
          • 767
          that's 8mm internal 13mm external right?
          hoping it's the soft line and a broken clamp..
          As for on the passenger side engine mount, what could that be?
          • Northern
            I like cupcakes & sh!tboxes
            • 5288
            8mm or 5/16" is OD for rigid line and ID for flex lines.
            Originally posted by priapism
            Originally posted by shameson
            • Sea Aych
              • Apr 2013
              • 767
              found the leak. One of the three hoses that are bunched together (return, charcoal or whatever and the one to the fuel rail) is wet and is dripping near the clamp to the other line near the dipstick, directly above the driver side engine mount, and a bit futher down towards the firewall (maybe 6 inches). I think it's the send line since it seems to drip faster when revved.
              The line looks in good shape from the top, so i'm not sure what's up. Will pop under tonight and take another look and replace.
              Just glad it's not a hard line.
                Replace that hose. The supply line to the rail is at >30psi. The other lines are at 0psi and less likely to be a problem.
