Idle Control Module failure?
  • LateFan
    • May 2013
    • 4438
    What are some symptoms of a failing Idle Control Module on an eta M20?
    Trying to narrow some things down.
    Thanks -
  • LateFan
    • May 2013
    • 4438
    bump....?
    • Mr. Tasty
      • Jul 2011
      • 3421
      Take it off, shake it. If it sounds like a baby toy then it is okay. If it feels solid and no movement, it is stuck and needs replacing.
      2014 Alpine White 335i MSport
      (Daily Driver)
      Full Mperformance Aero
      KW V2 Coilovers
      VRSF Catless Downpipes
      • LateFan
        • May 2013
        • 4438
        Nope, this is the ICModule, the little blue or green box next to the DME, which controls the idle control valve. I already replaced the ICV.
        But thanks!
        • Mr. Tasty
          • Jul 2011
          • 3421
          But thanks!
          oh, apologies.
          (Daily Driver)
          KW V2 Coilovers
          • srvE30
            Voodoo Child
            • Jun 2013
            • 408
            I like that gif. And I'm in on info for this idle valve issue as well.
            1989 325i Cabrio
            tyzg
            Midwest E30 Owners Gruppe Facebook
            • LateFan
              • May 2013
              • 4438
              Originally posted by srvE30
              I like that gif.
              Me too...I'm chuckling out loud...col??
              • Gregs///M
                • Mar 2012
                • 2459
                Unplug the connector and smell inside the case. If it smells burnt, its bad.
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                  After ruling out all other possible cause of an unstable idle, the module becomes the suspect.
                  • LateFan
                    • May 2013
                    • 4438
                    re: Greg - Well there's a basic test! I'll try it. Just bought a spare DME to try as well.
                    • LateFan
                      • May 2013
                      • 4438
                      OK, I'm getting there. It's down to too tight valve adjustment, the used FPR might be bad, DME, ICM, or wiring issues.
