m50 injectors on a m20b25
  • Snou52
    • Nov 2011
    • 176
    Hi all,
    first and foremost I would like to state that I did search and have been looking all day, but was unable to find my answer
    I have a very bad leaky injector and searching online I can't seem to find any refurbished ones for cheap like I see for the m50 injectors. I know folks have used them, usually with a AFM upgrade and chipped ECU. I don't plan on chipping my ECU or doing an AFM upgrade. can my stock ECU handle the 17.5lb injectors?
    it's weird I can find rebuilt m50 injectors for $120 shipped but can't find any rebuilt m20 injectors for that price.
    thanks in advance!
    1988 325is 237k
  • Snou52
    • Nov 2011
    • 176
    I should add that I don't have the 173 ECU....i'm not sure which one I have.
    I have an 88 325is...I thought it was the 173, but after trying the stomp test it doesn't appear so.
    1988 325is 237k
    • Snou52
      • Nov 2011
      • 176
      scratch this post...the short answer is yes, you can.
      1988 325is 237k
      • JinormusJ
        • 6887
        Yes; a late model i DME (153 or greater) can compute, process and remap for the slight increase in injector size
        The only thing that sucks is now your OBC MPG and Tach MPG gauge reading will be off due to the bigger injectors.
        The car uses electric signals it receives from the injectors in order to calibrate MPG. The stock 14# injectors run at roughly 80% duty cycle, while say, the 17# ones (being bigger) will only need to run at say maybe 50%.
        The computer will then take this drop in duty pulse as fuel savings, when in reality you are using the same amount of fuel, but running at a lower duty cycle
        There is a product sold by Seattle Circuits that fixes this problem for the OBC, however; I don't know if it will fix the Tact MPG gauge.
        • AndrewBird
          The Mad Scientist
          • 11892
          If you can afford the down time of not having your car, you might consider this:
          • Snou52
            • Nov 2011
            • 176
            thanks for chiming in fellas...I appreciate the extra info.
            Nitro - that's some damn cheap service! looks to be good work too!!!
            i broke the plastic cap on one of my injectors and it's spewing gas out so i'd still need to find one. i think i'll just purchase a set of the m50 injectors off of ebay. they're only $120 shipped and have been flow tested and rebuilt.
            1988 325is 237k
            • squidmaster
              • Aug 2011
              • 2666
              Mepeh is awesome, I highly recommend his service!
              • f4tj0n
                • May 2013
                • 411
                M50 injectors from Mepeh are $60+shipping. Why would you pay $120 off of ebay?
                • KVF
                  • 297
                  What they said
