Febi Cam opinions?
  • ser1992
    • Feb 2013
    • 482
    Febi Cam opinions?
    Im rebuilding my head and the cost of having my stock ones refurbed and a new Febi one is about the same. Are Febi stock replacement cams decent?
  • richard.bratton
    • Feb 2011
    • 99
    Febi replacement cams are great. I've used them in 10 or so spec e30 builds with great results and zero issues.
    • TheTacoMan
      • Nov 2011
      • 2308
      If you building a turbo engine and getting a new why not get a regind from Bimemrheads ? Almost the same price too.
      • SkiFree
        • Jun 2011
        • 2766
        How is this an opinion on the Febi cam? (no offence to bimmerheads, but that's not what the op is asking).
        I've sold probably 20 or so in the last couple years. Had 2-ish that were verified too far out of spec. So the odds that you'll be fine are heavily in your favor (shoot there have been a couple oem cams outside the tolerance range).
        ADAMS Autosport
        • digger
          • Nov 2005
          • 6196
          ive had 2 out of 3 catcams way out of spec so make of that what you want
          what particular specs are you referring to?
          • ser1992
            • Feb 2013
            • 482
            Thanks for all the input! I am not adverse to an aftermarket cam, I just don't want to run the risk of piston / valve contact. I have a resurfaced (not shaved) head with oringed block and goetze head gasket. I have heard of some (rare) cases of even a 272 cam pushing a valve into a piston. Thoughts?
            • TobyB
              • 5293
              Resurfacing a head is done by removing material. So is 'shaving', although i guess you
              might get less stubble with a shave.
              But no matter, if you're concerned, just use some modelling clay on the piston domes,
              then pre- assemble, roll it over and measure how thin the modelling clay got squished.
              If it's less than .080 or so, then it might be worth getting a little nervous.
              t
              • Myster-E
                Performance
                • 552
                t
                1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
                Visit www.BimmerHeads.com for all of your 12 valve needs!
                • ser1992
                  • Feb 2013
                  • 482
                  Ya, I meant it was "only resurfacing" not decking or shaving the head to raise compression.
                  Does anyone have experience with the IE 272? I'm searching for thread reviews but can't locate anything :/ It seems like a great value, I just don't want to buy garbage.
                    • 37833
                    IE 272 billet cams are very nice for the money. We've sold quite a few.
                    Grover Beach, California
                    BimmerHeads.com
                    • ser1992
                      • Feb 2013
                      • 482
                      Can I do the clay spacing test on another bottom end, since the bottom end I will be using is still being used in my car?
                      • blasphemy101
                        • Apr 2012
                        • 170
                        No, you would want to clay your block with your head just as it would be finally assembled. We're talking about clearances of less that .100" That's why you've read about some people having P/V contact while others are completely fine.
                        There is a method for testing clearance with the head on where you remove the valve spring and drop the valve onto the piston at TDC, but I imagine it's harder to measure accurately.
                        The Great Big M20 Timing Belt DIY
                        Some good information I've found online (no affiliation):
                        Turbo Tech (Garrett)
                        Four-cycle information and cam properties for beginners (ISKY Racing Cams)
                        • ser1992
                          • Feb 2013
                          • 482
                          cool, thanks for the info! I've got some decisions to make...
