Help with intake boot
  • anokES
    • Aug 2012
    • 206
    Hey, I was doing some work on my engine and noticed my intake boot was off - I have tried with all my might to slip it back on to the intake manifold but it just wont. Any tips or tricks to get it back on?
    Did you loosen the band clamp?
    • anokES
      • Aug 2012
      • 206
      Yes
      • dnguyen1963
        • Nov 2011
        • 2651
        Disconnect everything in front of the boot then you can put the boot back on the intake. Check the boot for cracks while your are at it. There is no point of putting a cracked boot on.
        • Eddie Haskell
          • 102
          FWIW heat the boot. Heat gun, hair dryer or anything. Brush a little caliper grease, silicon grease or soap around the T/B and it will slip on easy. Same applies for most rubber hoses.
          • essi1553
            • Apr 2012
            • 440
            I don't want to be a douche here, but why are you using "might" to slip an intake boot on?
            Start from the bottom, get a portion overlapping and just ease over. If its any more difficult than that, you have a different problem, probably still have the clamp too tight.
            • TobyB
              • 5297
              Or a really hardened boot- a new one is pretty pliable, but 25 years later, they do tend to
              get pretty rigid...
              t
