Help…what is this sprocket?
  • GOT8SPD
    • 270
    So I'm doing a timing belt/water pump replacement. I want to clean as much as i can because it's disgusting and full of oil and dirt, however, i got everything removed, i haven't MOVED the cam gear or the crank shaft at all…however! I moved this sprocket…is that bad?!?!?!? See the RED BOX. I totally forgot to not move anything so i can just slip the new belt on.
    Secondly, I want to clean the sprocket on the crankshaft…is there anyway to remove this cover without pulling all the gears off? I want to clean all this crap off...
    • 37828
    That's attached to the intermediate shaft which drives your oil pump.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
      Correct and it doesn't matter if it moves.
      • Poorboyz
        • May 2012
        • 2117
        Also, as a FYI...I always use a whiteout pen to mark pulleys/sprockets.
        Sent from my Galaxy Nexus using Tapatalk
        Rebuilding since 07/06/2016
        Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
        Poorboyz Feedback Thread
        • delamaize
          • Nov 2013
          • 1435
          +1 for oil pump....
          Dumpster Fire Pilot
          • Sirotto
            • 317
            Nope
            "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
            "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
