rocker arm question
  • blownm20
    • Jun 2012
    • 39
    rocker arm question
    Can you use the rocker arms from a m20b25 on a m20b27. I'm planning to swap over rocker arms from this I head that I have to my eta head. Reason being I broke an exhaust rocker on my 86 eta (cylinder one). I know I know yes just the rocker arm
  • dwight
    • Dec 2012
    • 550
    just check the part numbers on the side of the rockers
    • Cabriolet
      • 9620
      yes, they are the same.
      Much wow
      I hate 4 doors
      • digger
        • Nov 2005
        • 6122
        physically things will fit but i would not recommend swapping in a used rocker arm from one engine to another. the rocker and cam "wear in" together so using a rocker that is worn in on one cam wont mate well with a different cam and could wear out extremely fast.
        ive yet to see a moderate to high mile engine have a cam with no wear, same with rockers and i have stripped about a dozen heads in the last coupe of years.
        • essi1553
          • Apr 2012
          • 440
          get new rockers, period.
            Examine the rockers where they ride on the cam. If a dip hasn't been won in the wear pad they can be used on any cam.
              • 37829
              I would definitely recommend new rockers or at least replacing the broken with new.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • blownm20
                • Jun 2012
                • 39
                Originally posted by MR 325
                I would definitely recommend new rockers or atIeast replacing the broken with new.
                I might just replace the one rocker.. not the ideal thing to do but i dont want to spend money on the eta. Reason behind my question is I want to rebuild the I motor completely. So if I could reuse the rockers into the eta just to have something to drive for the time being I will do that. I dont care if the motor wont last me the next month. Also the wear on the cam is minimal. No major scouring. No dips.
                Anyways thank you everyone
