running temp for m20
  • Snou52
    • Nov 2011
    • 176
    hi all,
    my temp gauge is on the fritz and I just swapped my motor...can anyone tell me what the running water temp should be for the m20 and at what temp does the engine start overheating?
    thanks
    1988 325is 237k
  • efficient
    • Feb 2012
    • 3312
    The Gauge on crusing/ highway should be like at 11oclock and in traffic it should be in the middle. Anything over is not correct. Well thats how my car is
    • Snou52
      • Nov 2011
      • 176
      i'm thinking of just adding an after market water temp sensor...I've done everything possible to fix the one in the cluster.
      I think running water temp should be around 210-220 degrees? does that sound right?
      1988 325is 237k
      • digger
        • Nov 2005
        • 6120
        Originally posted by snou52
        i'm thinking of just adding an after market water temp sensor...i've done everything possible to fix the one in the cluster.
        I think running water temp should be around 210-220 degrees? Does that sound right?
        175-200F is normal it gets to 115F in summer here
        210 to 220 is too hot IMO and indicates a problem with the cooling system.
        • Cabriolet
          • 9620
          very true. your cooling system is having issue. re bleed your system. if that doesnt work. you will need to figure out if you are running too lean, have a system clog, bad thermostat, etc
          Much wow
          I hate 4 doors
          • codrum
            • Jan 2011
            • 279
            I agree with this. I only have a mechanical fan (removed AC, don't have an electric replacement) I sit at about 185-195 with normal around town driving and highway cruising. When I'm sitting in traffic it'll spike up to around 200 but I've never seen it jump up more than that.
            • Snou52
              • Nov 2011
              • 176
              thanks for the input everyone....time to chase it down
              1988 325is 237k
              • bddog
                • 351
                Sometimes, it can take awhile to get the air worked out of these things.
                When replacing my thermostat I always use a "fail open" one. A couple of dollars more
                but well worth the peace of mind.
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  Don't know my running temp but it's at the first mark were the blue is, so halfway to mid temp.
                  1992 e34 Touring- S50 Swap
                  1992 325i-S50 Swap (SOLD)
                  1991
