2.7 stroker wont go past 3500 rpm
  • MrK
    • Jan 2006
    • 709
    I just finished my stroker project (minus the smt-7... still waiting for that), and I'm getting this weird problem that I can't figure out:
    The engine won't rev past 3.5k when stationary, and won't rev past 3k rpm when moving. If I LIGHTLY press the accellerator though, I can edge past this point and SLOWLY build more revs. My narrowband a/f gauge is showing me a drastic leaning at around that same point.
    My first thought was unmetered air, but the car idles fine and is very smooth from idle UNTIL 3.5k rpm. I checked hoses etc anyways, and found nothing.
    My second suspect was the 2.7 chip I had put in. Swapped it with the original chip, same behaviour..
    Any ideas as to what's causing this?
    Background info:
    2.7 stroker using high CR pistons
    304 degree schrick
    535i injectors
    2.5 bar FPR (the 3.0 made it stumble and stutter badly)
    normal m20 AFM (working properly.. I checked)
    This is your M20 on steroids:
  • var1ant
    • Apr 2005
    • 509
    From what I understand, the m30 injectors aren't going to work because they are high? impedence or something? someone verify please.
    '87 alpine white 325is
    • MrK
      • Jan 2006
      • 709
      No the injectors have worked before... so that can't be the problem. I'm thinking maybe it's the adjustable cam gear...
      • der affe
        Technical
        • Dec 2005
        • 8452
        slightly off topic, but what was the 3.0 fpr from, and what was the 2.5 frp from?
          • 34844
          3.0 is standard M20B25, 2.5 can be found on ETAs.
          • MrK
            • Jan 2006
            • 709
            fixed the problem for the most part. Funny enough, replacing the 2.5 bar with a 3.0 bar again and using hotter plugs eliminated 80% of the problem. Still stutters RARELY at sustained high rpms, so I'm gonna review the fueling system again.
            Oh, and I used the 2.5 bar from a 320i, but I'm sure it's the same 2.5 that the eta has.
            I'll ditch both FPRs and install my bavauto AFPR as soon as I find a freakin fuel pressure gauge in this wasteland...
