improving mpg on stock m20?
  • CrazyJew89
    • Oct 2009
    • 347
    Q5Quint is completely right. It is kind of amazing what you can get when you start doing aero mods
    Originally posted by Q5Quint
    decrease wind resistance (easy, just drive slower, or hard, add add splitters and a pan under your car)
    Be careful here, aerodynamics can be finicky: http://www.autospeed.com/cms/A_2160/...popularArticle (TLDR: Do your diligent testing. One of this guys iterations ended up with him getting backwards airflow through his hood scoop. Yes, backwards!)
    '87 5-speed 325is
    The best $750 I ever spent!
    Are you in Michigan?
    Do you want to know where all the E30's are?
    Try checking out the Michigan E30 Map
    • Q5Quint
      • Jan 2005
      • 725
      swap in an eta motor
      haha! Or could swap in a m10, I was getting about 35mpg highway with that little guy.
      Holy moly this website is hilarious:
      New Ideas:
      Wheel skirts.
      Underbody pan (make sure radiator is still flowing properly)
      delete roof rack, spoilers, side mirrors.
      tape all body seams
      chop top
      add boat tail
      ride height reduction
      low viscosity oil
      increased c/r pistons
      power steering/ac/mech fan delete
      synthetic wheel bearing grease
      synthetic lube transmission and diff
      low rolling resistance tires- increase pressure
      weight reduction
      This bastard is getting 70mpg out of a geo!
      • digger
        • Nov 2005
        • 6121
        best thing is to control your right foot
        • dnguyen1963
          • Nov 2011
          • 2649
          New Ideas:
          Wheel skirts.
          tape all body seams
          chop top
          add boat tail
          low viscosity oil
          weight reduction
          Just don't sit in the back or the rear end will hit the ground.
          • CrazyJew89
            • Oct 2009
            • 347
            70mpg, that's nothing. Check out the AeroCivic
            '87 5-speed 325is
