Replaced Tbelt, valves tick louder
  • Tylerse30
    • Sep 2012
    • 54
    Hey guys, wondering if I replaced my timing belt and put the right tension on it, I had the motor out and the entire front of the motor apart replacing the lower crank case gasket, so I threw in a new Tbelt and water pump, put the engine to TDC and matched the timing marks on the dot. Pretty sure I tightened the tensioner the right way. For some reason the engine ticks louder than it did before. I've owned an m20 for years and I know what loud valve noise is, but it just seems too loud. Any ideas? Could a some what lose or over tightened Tbelt affect that noise or no? Help me out here
  • rmdashrf
    • Feb 2014
    • 207
    I don't think so? When was your last valve adjustment?
    • Tylerse30
      • Sep 2012
      • 54
      Can't remember to be honest, could give that a try
      • CabbE30
        • Aug 2009
        • 2358
        Nope to your question. If you cant remember the last valve adjustment then it's due.
        The only thing I can think of is if the timing is off the valves could kiss the pistons. (doubt it)
          • 37833
          The timing belt can't make the valves tick any differently.
          Grover Beach, California
          BimmerHeads.com
          • digger
            • Nov 2005
            • 6181
            if it breaks you get one big tick and it is quiet
              • 37833
              Well you've got me there! :D
              BimmerHeads.com
