Regarding the schrick 284/272
  • digger
    • Nov 2005
    • 6148
    post up the valve relief specs can compare to stock. i'm sure youll be fine as its a turbo cam with wider LSA stated as 1.9mm/1.4mm lift at TDC for intake and exhaust respectively which is barely more than stock. to check 100% you can use clay or something like that but unless they screwed up the manufacture (which does happen) it'll be fine
    • downforce22
      • Aug 2009
      • 3192
      My pistons are dished with -9 net piston volume. Bore is 86 mm, dish depth .085 (2.16mm), comp height 26.39 mm intake depth .156 (3.96 mm) at 22 degrees from deck, exhaust .156 (3.96 mm) at 22 degrees from deck. I believe my cylinder head was resurfaced 0.005" which is .127 mm. I will dig out my records to confirm.
