Oil Pan Gasket Help.
  • E30NJ
    • Aug 2013
    • 921
    Ok so finally I can start to DD my E30 (thank god for spring!;D). The annoying part is leaving some form of oil or fluid everywhere I park. So far I did rear main seal, power steering lines/ reservoir, valve cover gasket, and obviously oil change/ filter and the diff is bone dry. Problem is, I still leak oil from mainly the oil pan. I know its never going to be leak free but I need some help doing the oil pan gasket because that's where it is mainly coming from. Any tips/ advice? I'm going to do the process of lifting the engine instead of dropping subframe.
    Thanks!
    • 37827
    We always use a paper gasket (not cork) with a nice coat of a product called Gasgacinch.
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • redlightpete
      • Mar 2012
      • 262
      There's no reason your e30 can't be leak free. It's German not British.
      • enigmaticdream
        • Jan 2010
        • 572
        I just did this a few weeks ago.
        -raise the engine enough to get the oil pan out.
        -buy some anaerobic gasket maker
        -clean up pan and block surfaces.
        -apply anaerobic gasket and reinstall
        Anaerobic gasket cures in the absence of air. I've been using it for a few years now in placement of POS cork and paper gaskets.
        1986 911 Supercharged Frakenstrat/Stripped
        1987 325is Delphin/Black (Olga)
        1988 M3 Zinno/Natur (Elsa)
        Manual or STFU
        E30 Chapter of BMW Car Club of America
        E30 Oktoberfest 2017
        • mpowerful
          • Jul 2013
          • 1273
          Go to your bmw dealership and get a tube of hylomar. Itll leak through the aluminum before it leaks through that.
          • NYSE30
            • Nov 2013
            • 166
            Would hondabond work in this case as well for the oil pan? I don't see why not, anyone disagree?
            • ginger1340
              • Jun 2015
              • 167
              sorry to revive such an old thread but why do you have to jack the engine up? is it just to get clearance to get the bolts out?
              • TimeMachinE30
                • Jun 2014
                • 3749
                [QUOTE=ginger1340;4448201]sorry to revive such an old thread but why do you have to jack the engine up? is it just to get clearance to get the bolts out?For removal.
                ACS S3 Build / Dinan 5 E34
                • ginger1340
                  • Jun 2015
                  • 167
                  [QUOTE=TimeMachinE30;4448220]
                  its 100% necessary for removal of the oil pan?
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    From my reading and understanding, the subframe is in the way. Either the subframe comes out or the motor can be lifted just enough to make removal of the pan possible.
                    • SkiFree
                      • Jun 2011
                      • 2766
                      Yes.... or get under there and look at it, it gets apparent real quick.
                      ADAMS Autosport
                      • jayamasaki79
                        • Oct 2014
                        • 342
                        does anyone have the part # for the M20 e30 oil pan gasket ?
                        looking to go to the dealer today, unless someone know where i can get the OEM one cheaper ?
                        • himandey
                          • Jul 2012
                          • 53
                          I purchased the MTC paper oil pan gasket along with some hondabond off of amazon.
                          Edit: Literally everyone is out of stock for the MTC gasket. Guess I gotta go rubberized cork oem...
                          • turbo55
                            • Jul 2014
                            • 223
                            [QUOTE=ginger1340;4448222]
                            Yes. Otherwise you a). won't be able to get the oil pan out past the oil pump and oil pressure sensor and b). won't be able to scrape the old gasket off above the subframe
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              I have used Permatex "The Right Stuff" on dozens over the years, zero leaks. Just a small bead smeared flat. You can put the item in service immediately, no cure time.
                              john@m20guru.com
                              Links:
