Very strange noise
  • ramirez54
    • Jun 2008
    • 128
    Very strange noise
    Hey guys can you help me figure out this noise coming from my m20. Check out this video:
    Recent work:
    Water pump, thermostat, fan clutch, fan, rotor and engine oil (level is correct).
    Any input would be greatly appreciated.
    C
    1989 M3
    1991 M5
    1997 M3 (Technoviolet)
  • dnguyen1963
    • Nov 2011
    • 2649
    It sounds like your fan is hitting something after the rev.
    • ramirez54
      • Jun 2008
      • 128
      Thanks, yeah I'll check that out tomorrow in the day light. I texted this video to my friend who is a mechanic. He mentioned it could also be a loose belt. I'll check those two items out tomorrow.
      1989 M3
      1991 M5
      • Sea Aych
        • Apr 2013
        • 765
        Wouldn't that depend on if that video is when the car is warm? If it's cold, would the fan even spin?
        1988 Atlantisblau Euro/Japanese 325i Cabriolet
        1989 Schwartz 325i - now M50 powered! - now very dead
        1998 Toyota 4Runner Limited
        My 17,000km Big NA National Parks trip!
        • dnguyen1963
          • Nov 2011
          • 2649
          Have you watched his video? The fan was spinning.
          • NeedaE30
            • 397
            its probably your lower radiator hose being hit by the fan, just an assumption
            • EyExR
              • Jan 2011
              • 959
              Well, first of all, you need to do a valve adjustment. I can hear that for sure....
              The sound you're worried about sounds like the fan blades scraping the radiator at some point....
              My 325iX DIY Threads:
              Front Wheel Bearing Replacement
              325iX Rear Subframe Bushings and MUCH more w/pics!
              325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
              • cabriodster87
                • Jan 2011
                • 1042
                Sounds like something down in the timing belt cover.
                Reich und Roll!
                • wickeddirtye30
                  • Nov 2013
                  • 6
                  Pull your valve cover you could have a loose rocker arm bouncing around under the cover
                  • EyExR
                    • Jan 2011
                    • 959
                    Is that a NEW fan clutch?
