Will Not Fire
  • Erodras
    • May 2014
    • 29
    Will Not Fire
    After pulling my injectors and rebuilding, they car is turning over, but not firing. I have checked all hoses and connections, but all things are in their place. Any ideas on what it could be? 1989 325i m20b27, stock injectors.
  • Sea Aych
    • Apr 2013
    • 765
    Checked your fuel pump? Are you getting spark?
    1988 Atlantisblau Euro/Japanese 325i Cabriolet
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited
    My 17,000km Big NA National Parks trip!
    • Erodras
      • May 2014
      • 29
      It worked fine before hand, if it were the fuel pump, how could I tell?
        Might you have gotten the fuel supply and return lines swapped?
        • Erodras
          • May 2014
          • 29
          No sir
          • Erodras
            • May 2014
            • 29
            Here's a link to an album, pictures of all the parts involved in what I did. http://imgur.com/a/wrscJ
            • NeedaE30
              • 397
              stupid question i know, but are the fuse/relay back in place? :P
              • Erodras
                • May 2014
                • 29
                Nothing of the sort was tampered with, it's all where it was before.
                • Erodras
                  • May 2014
                  • 29
                  I checked the fuel pump relay and main relay, both click once when the ignition is turned on.
                    • 34844
                    Are the crank sensor and CID plugs bacwards?
                    • b1mm3r
                      • Apr 2014
                      • 184
                      Jump fuel pump relay number 87-30 and see if it comes on, you can disconnect fuel feed line and see if fuel comes out also.
                      87 325e DD--93 318is s50--07 3.0 X5 wifes
                      • Erodras
                        • May 2014
                        • 29
                        Found out, no Injector pulse. Checked the connectors and everything is in place. What could be causing the issue?
                          • 34844
                          no crank signal = no injector pulse
                          • Erodras
                            • May 2014
                            • 29
                            Brand new CPS
                              • 34844
                              doesn't mean the signal is getting to the DME.
                              are you sure the CPS and CID weren't switched around?
                              does the DME for 100% sure have power?
