NGK dont fit?!?!
  • lukey30
    • May 2014
    • 39
    NGK dont fit?!?!
    My engine was missing just barely, so I pulled spark plugs first, like anybody would do. spark plugs were disgusting. I go down to Orielly's, pick up NGK plug - correct temp and plug for the m20.
    MOTHERFUCKERS WILL NOT FIT ON THE DAMN WIRES?! IM BEYOND PISSED!!!!! its the simplest thing in the world and they literally will not fit. I noticed that the tops (where the wires go on) is different, and actually significantly. after some searching, I found that I do have the right plugs - ZGR5A part #5077.
    Someone tell me what the fuck is going on here please
    Thanks much and sorry for the blind rage.
    GOD DAMNIT!!!!!!!!!:hitler::hitler:
    1989 325i
  • Danny
    • 14216
    There is a threaded cap on the top of the plug. Unscrew it with pliers.
    • Andy.B
      • Sep 2011
      • 1650
      Is the top of the spark plug a threaded shaft or smooth, roundish metal tip?
      It should be threaded for the e30 plugs. On most plugs the stud is removable, and will twist off with pliers, but some are fixed, so don't go all hulk hands with it and break the plug.
      • lukey30
        • May 2014
        • 39
        :Oh my god. the tops screw off and work fine. please excuse my incompetence im not this retarted
        1989 325i
        • Andy.B
          • Sep 2011
          • 1650
          Haha. I think everyone who has ever worked on a car has had that EXACT moment at one point. The more forgetful ones probably more than once.
          I KNOW about this, and still forget to screw the stud off nearly every time I replace spark plugs. I get all 6 in, try to re-install a plug wire, slap my forehead, and well... you know the rest.
          • LJ851
            • 7919
            Did this work ?
            O'reillys has the wrong ngk plug listed for our engines and it has a fixed cap on it. If this is the case, return them for the correct plug.
            Lorin
            The M30 is God's engine.
            • SkiFree
              • Jun 2011
              • 2766
              For what it's worth, this just made my day.
              ADAMS Autosport
                • 34839
                I'm sure O'reillys recommends a platinum plug too. I know Napa does. ugh.
                • Liquidity
                  • May 2014
                  • 395
                  This is one of those moments where you could learn that a bit of research could have saved you from this embarrassing fiasco.
                  • mitchlikesbikes
                    • Dec 2013
                    • 858
                    if you lose your mind like that over plugs what's gonna happen when you accidentally get your girlfriend pregnant? :O
                    IG: @mitchlikesbikes
                    • LJ851
                      • 7919
                      Yes it was a platinum POS.
                      Lorin
                      • htown318is
                        • Feb 2012
                        • 301
                        I remember my first encounter with this. Was like dafuq it screws off?
                        • lukey30
                          • May 2014
                          • 39
                          hahahah im glad a noob to the forum could make everyone laugh...
                          I was a toyota crawler guy before i bought my e30 and have never even heard of plugs unscrewing.
                          senior year highschool girlfriend thought that would be a funny joke. she calls me and said i have to come over immediatly. i run 2 stop lights. says shes pregnant. i just about shit myself. she goes "PAYBACK ASSHOLE":cockbloc:
                          Lesson learned - better to ask for permission than forgiveness (attempted the back door when highly intoxicated)
                          1989 325i
                          • digger
                            • Nov 2005
                            • 6128
                            went to buy some NGK BPR6ES and knew i had to unscrew the little bastards on the end. except i bought NGK BPR6ES-11 by accident which look almost identical and when i unscrewed them the whole centre electrode/core came out to. probably should have realized something was up when it took about 4 times the effort
                            • E30Gus
                              • Jun 2008
                              • 781
                              if you lose your mind like that over plugs what's gonna happen when I accidentally get your girlfriend pregnant? :O
                              Fixed that for ya
