will a bobbed crank for 2.8l stroker balance out?
  • digger
    • Nov 2005
    • 6182
    Originally posted by redlightpete
    2. Is it a problem that the counterweights are smaller? No. It might be an issue in a vee configuration or a single, and then you might add "bob" weights to compensate.
    yeah its not like there are no counterweight which would be a problem, they are still substantial even after machining
    • LJ851
      • 7919
      You are confused. The bob weight is a calculated percentage of the weight of the rod and piston. The bob weight does not change to compensate for crank mods.
      On a 90 degree V engine (single pin) a balance factor of 50% is typical. If the counterweight of the crank is not heavy enough to counter the required bob weight, holes will be drilled in the counterweight and heavy metal is inserted.
      None of this applies to an inline 6 crank as previously mentioned.
      Lorin
      The M30 is God's engine.
      • redlightpete
        • Mar 2012
        • 265
        Sorry for the additional confusion regarding bobweights.
