m20 valve cover breather size
  • 325est13psi
    • 267
    hi r3v!
    im at work about to grab some hose to replace the valve cover breather to the
    throttle body, does anyone know or have a valve cover lying around to take a measurement of the diameter of the nipple on the valve cover??
    3/4?
    thanks for your help!
    -christian
  • jaywood
    • Jul 2010
    • 4528
    I believe 3/4" will work for you.
    • 325est13psi
      • 267
      thank you!!
      • TheTacoMan
        • Nov 2011
        • 2308
        I believe its 3/4" OD.
          • 37833
          The OEM BMW hose is $8. Why run bulk hose?
          Grover Beach, California
          BimmerHeads.com
          • digger
            • Nov 2005
            • 6194
            the cover is 22mm OD so something a little smaller in size for the hose ID will work
