lightly scratched rocker shaft bores; is the head junk?
  • wakeboardr42393
    • Apr 2013
    • 186
    Hey, when i was pulling my rocker shafts, I slightly marred the rocker shaft with pliers that ate through my "cushion" material, which made some pretty light scratches on the first two rocker shaft bores when removing.
    I'm assuming the head is ruined but just wanted to get another opinion on this.
    thank you! :)
    '87 325is [because racecar]
    '81 Kawasaki KZ550 LTD {summer dd}
    '97 Subaru Legacy Outback Limited (winter dd)
  • LJ851
    • 7919
    If i made what i would consider a very light scratch in the rocker bores, i wouldn't sweat it. Try to knock down the high points of the marred aluminum so the new shaft will slide in smoothly.
    Lorin
    The M30 is God's engine.
    • TobyB
      • 5287
      Dear God, it's fine!!!
      t
      • SkiFree
        • Jun 2011
        • 2766
        Define "lightly scratched",
        to some people that means "It looks like Godzilla took a bite out".
        We're assuming it's more like "A butterfly pooped on it and now it's a little rough."
        ADAMS Autosport
        • jeffnhiscars
          • Jun 2011
          • 6011
          If you are referring to the aluminum towers that the rockers go In And not the rockers themselves, those are not friction surfaces and the shafts don't move. I'd use some fine wetndry so you don't score the shafts when re inserting them and obviously clean up after yourself.
          Butterfly poop ? Never seen any in an M20 ;D
          Alice the Time Capsule
