Schrick 284/272, 288 + adjustable cam gear?
  • kuerone
    • 13
    Hello guys,
    I have a question. With my friend we build two m20b28 stroker's and we have one problem.
    My engine gets schrick cam 284/272, and my friend 288. So question is simply and mayby funny Do we need a adjustable cam gear?
    if so, someone will remember as long as you need to move the timing belt on these camshafts?
    Btw... I use new m20b25 8.8:1 cr mahle oversize pistons, and my friend use used m20b25 9.7:1 cr mahle pistons.
    One picture of my setup...
    Thanks!
  • Bullet Ride
    • Dec 2010
    • 598
    Degree your motor and you'll find out.
    Chances are you'll need to adjust the cam timing to get it in spec.
      • 34847
      Its worth the $90. You can adjust your torque for the most area under the curve on a dyno. A few degrees can make a big difference.
      There is a sweet spot where you can retain a broad torque curve with minimal sacrifice in HP, that should be your aim.
      • SkiFree
        • Jun 2011
        • 2766
        I gave you a one word answer here....
        Chances still remain very likely that you'd benefit from one.
        ADAMS Autosport
        • digger
          • Nov 2005
          • 6199
          its a no brainer, chances of the cam sitting where it runs best is slim. bang for your buck is pretty good.
          • kuerone
            • 13
            We want to buy a catcams cam gear. Is not expensive, but it actually can make a difference
            Yes, I saw this but I thought that someone will tell me something more about it.
