Fuel lines
  • thatphysicsguy
    • Mar 2013
    • 843
    Fuel lines
    Hey all, doing a large service to the b25 soon and I was wondering what size/spec of fuel hose the car needs? Are there different sizes across the car? or is there one size used pretty much universally?
    I want to buy a roll of hose and cut it to length for each of the applications if possible.
    '91 325i
  • RUFFLZ
    • Apr 2011
    • 3122
    in to get schooled on this.
    just bought a couple meters of BMW 8x13 hose to take out a couple lines, anyone have a diagram of what else I would need?
    realoem's diagram is pooey
    • FLG
      • Sep 2011
      • 3165
      Hit up Levent at guten parts he has brand new hard line for the entire car for super reasonable and can also supply you with the rubber line.
      Sent from my SCH-I545 using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • 37833
        The soft line is 8mm or 5/16" but make SURE it's rated for fuel injection. Not just fuel hose.
        Grover Beach, California
        BimmerHeads.com
        • dougie30
          • Apr 2012
          • 1708
          I went to autozone and asked for high pressure rubber fuel line and I just cut it to length and used two barbed fitting with hose clamps, has been working for about 3 months no problems.
          M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
          • jeffnhiscars
            • Jun 2011
            • 6011
            I bought 5 meters of FI rated hose from autohausaz. It's made by Conti who makes a ton of OE parts, costs about $30 and is enough to do 2 cars under the hood.
            Alice the Time Capsule
            • thatphysicsguy
              • Mar 2013
              • 843
              so it works for the soft lines in the back by the fuel filter/fuel pump too? or could those be different sizes?
              '91 325i
              • FLG
                • Sep 2011
                • 3165
                From tank to pump is diff size if early model.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  the pump to filter hose is molded in a U. Ive gotten by with a standard piece of hose but it wants to kink.
                  • TobyB
                    • 5268
                    ...but yea, on a late car, all the fuel line will be 8mm/ 5/16".
                    On an early car, you'd need some 12mm from the tank to the
                    HP pump. A little more/ less than a meter?
                    t
