Main Seal!!!
  • Zeckler1234
    • 8
    Main Seal!!!
    Can a main seal failure cause a vacuum leak? My car is throwing the 1222 code and the mechanic I am working with thinks its the main seal. Please help asap!!
  • Zeckler1234
    • 8
    Please help! If the main seal is the problem I am just going to do it myself and not spend 600 for the guy to drop the tranny. I just want to make sure that the main seal can cause a vacuum problem..! Thanks!
    • TobyB
      • 5220
      If you have a vacuum leak at the rear main, you also are driving the Exxon Valdez.
      Otherwise, it's not the rear main.
      t
      • Zeckler1234
        • 8
        So should I call the guy out?
        My oil pan gasket is a little leaky can that cause a vacuum problem?
        Mechanic says he sprayed brake cleaner near the trans and the rpm went up, keep in mind this car has a slush box.
        • Zeckler1234
          • 8
          If the rear main fails can that cause loss in pressure in oil pan?
          • glnr13
            • 1334
            that's quite a job to hunt down a vacuum leak.
            have you done a smoke test? are all your hoses in good shape? ICV? AFM? Throttle position sensor? O2 sensor?
              A leak at any seal or gasket of the block can result in an intake leak. A properly conducted smoke test will tell if there are any leaks.
              A bad front (or rear) main seal is very unlikely to cause an oil pressure problem.
              • crappycoco
                • May 2014
                • 250
                And its best to smoke the car cold (morning cold, not drive to the shop and leave it for an hour cold).
