Compression test questions
  • dewme5
    • Mar 2014
    • 165
    1 = 120
    2 = 110
    3 = 125
    4 = 125
    5 = 120
    6 = 110
    Warm engine. 89 M20b25
    I've been guessing that my timing belt is one tooth off. Power seems a little low, and acceleration seems a little slow.
    I've replaced the complete fuel system, new injectors and chip, and adjusted valves.
    Passed smoke test.
    The idle is just a bit rougher then it should be.
    I've seen a few other posts with similar compression test numbers, but nothing really resolved. Any suggestions?
  • Cabriolet
    • 9620
    that's pretty low. anything bellow 135 would have me worried. normal is 165-185
    Much wow
    I hate 4 doors
    • JinormusJ
      • 6887
      Numbers are definitely low
      Old e30 had 160 average
      The iS has 150 average
      M3 has 2 cylinders under 110, but it has known head gasket issues
        Numbers are low, but pretty uniform. That could be mistimed cam, worn/misadjusted valves, or worn rings. Assuming the test was properly conducted with the throttle locked wide open and fuel injection disabled. A leak down test will tell more.
        • dewme5
          • Mar 2014
          • 165
          I think there are just to many clues to a mis-adjusted timing belt. I'm going to get a new one, redo the timing, and will post results.
          • digger
            • Nov 2005
            • 6216
            you dont need to redo the timing belt unless it is way off you should be able to see/check that without actually changing it...?
            • dewme5
              • Mar 2014
              • 165
              1 tooth off, is off enough to cause all the issues I am experiencing. On top of that, I have no idea when it was changed previously. I bought this car from auction, so everything I haven't changed is questionable.
                In that case, change the water pump and fan clutch along with the timing belt & tensioner
                • dewme5
                  • Mar 2014
                  • 165
                  Well, it looks like it wasn't the timing belt. Good thing I got in there, the belt was cracked, and didn't have long left on it. However, the marks line up correctly.
                  Yesterday, while picking up a few things at the parts store, I figured I would try a bottle of "guranteed to pass smog" stuff from stp. Poured that in, and topped off the tank. Drive home was short. 3 miles ish, and parked for the night. When I got in it this morning, the idle was smoother, and felt like just a bit snappier performance. Nothing amazing, but just a subtle difference. I'll run another compression test after everything gets reassembled. Have to wait 3 more hours for the waterpump.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    9 times out of 10, the valves were burnt on m20's I have opened up with low compression numbers. The exhaust valves tend to get pitted. Do a leak down test to confirm, but chances are you need to rebuild the head. Typically after a head rebuild I will see 175-185 cranking compression with a stock cam, and 160-170 with a 272 (more overlap decreases cranking compression).
                    john@m20guru.com
                    Links:
                    • dewme5
                      • Mar 2014
                      • 165
                      Good info. and Damn it! I don't want to rip the head off......
                      • digger
                        • Nov 2005
                        • 6216
                        can you not do a leakdown test before you assemble back together.its not hard to pull the head
                        • dewme5
                          • Mar 2014
                          • 165
                          I know pulling the head isn't difficult, just time consuming. Work has me moving around alot, so I don't have a garage, don't know any reputable machine shops, and can't have the car down for long. I don't have a leak down tester out here, and lack a compressor as well.
                          Just finished putting on the timing belt. Everything went smoothly, and power seems to be what it was before. I've run most every option possible prior to a rebuild or replacement. I've found a clean head for sale just a few hours away, so i might go get that. I'd really like to get a leak down first, but I'm headed towards the head tomorrow morning anyway, if he gets back with me, I'll just plan on picking up and swapping the head
                          Sent from my HTC6435LVW using Tapatalk
                            Well, it may not be the head. Have a shop run a leak down test and you should then know if it is the head or the rings.
                            • dewme5
                              • Mar 2014
                              • 165
                              The one part that bugs me, prior to any other testing, is all the numbers being uniformly low.
