Loud metal clash while driving, no longer starts
  • Chilezen
    I weld cats
    • Dec 2013
    • 1937
    Video of attempted start
    Turns over, doesn't fire. There does seem to be a faint knocking sound on the bottom end.
    I was driving normally, accelerating from a stop, and without warning I hear a loud metal-being-annihilated clash. It was similar in nature to grinding gears, but lower pitched. I coast to a stop and push it to a parking lot. Towed home.
    There are no leaks, no fumes, no external damage within the engine bay.
    Previously, for several months, this car would stall at idle and cut out during acceleration (but continue running). I don't drive it often for that reason. But otherwise it runs fine.
    The timing belt is new and fine, it still rotates the cam. This leads me to believe the valves didn't hit.
    I can't mentally piece together the loud sound with the car not starting, given that I hear no clashing sound during the attempt to start it. I don't understand why the engine still turns over if there *is* metal broken. And if there isn't metal broken, why won't it start?
    Currently building a badass coffee table
    Random stuff on insta @kevanromero
  • ahlem
    • 369
    What do you see when you take off the valve cover? I'm guessing you broke your timing belt. You can pull the rubber cover off the front of the drivers side of the motor and look for rubber teeth.
    • Chilezen
      I weld cats
      • Dec 2013
      • 1937
      I haven't taken off the valve cover yet.
      • 15Michaeljoseph
        • Aug 2013
        • 1693
        +1 although when mine went it wasn't really metallic sounding, but you could hear the thwacks as the valves hit, really fast. that 'oh sheit' moment every e30 owner fears.
        --Mike
        (OO=[][]=OO) For Life
        • AndrewBird
          The Mad Scientist
          • 11898
          Pull the dip stick and see what the oil looks like and report back.
          • vpilarrt
            • Jun 2006
            • 2096
            So how do you know that the cam still rotates?
            • Chilezen
              I weld cats
              • Dec 2013
              • 1937
              I have now pulled off the cover, the cam does indeed rotate:
              The oil on the stick looks clean, I changed it about a month ago.
              A compression test is next.
              • Chilezen
                I weld cats
                • Dec 2013
                • 1937
                Update:
                • econti
                  • May 2014
                  • 1149
                  that's an issue
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    You have at least one broken valve.
                    Ouch.
                    Pray it didn't take out a piston as well.
                    • Chilezen
                      I weld cats
                      • Dec 2013
                      • 1937
                      Cylinder 6 has no compression (I wonder why...). The rest are fine.
                      How can I check the valves? I can visibly see the rockers moving those valves.
                      Sooo, what do I do? I spent $2k on the rebuild only 1,000 miles ago.
                      • mr.vang
                        • 4371
                        Time for s52 swap
                        • Chilezen
                          I weld cats
                          • Dec 2013
                          • 1937
                          The exhaust valve is still pressing against the rocker, even though the cam lobe is on the other side. It's as if the keepers aren't keeping it down.
                          I have no money for any swap or another rebuild. If the valve is the only problem, I may have enough $ (in time) to replace it, assuming the piston and cylinder wall is intact.
                          • smooth
                            • Apr 2005
                            • 1940
                            Call the person who did the rebuild.
                            Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                            • Chilezen
                              I weld cats
                              • Dec 2013
                              • 1937
                              Thanks for the suggestion, but as you'll see in my sig, I did the rebuild.
