Air box question
  • HennaE30
    • Apr 2014
    • 1965
    Air box question
    So I just bought an air box for my car for pick n pull.
    What is this piece that clips to the inside where the afm is? What does it do? Do I need it?
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • Daeldalus
    • Nov 2012
    • 304
    that is the velocity stack that helps increase the speed of the air entering your intake.
    you do not NEED it but it certainly helps with airflow and power so it is a wise piece to keep
    • digger
      • Nov 2005
      • 6216
      its there to attenuate sound and provide low flow losses (its radiused like a bellmouth) into the AFM and a more uniform flow (straighten the flow ) regime to the AFM. if you can figure out how to shorten it about an inch (so it is not so close to the wall) it will provide a better flow path it might help very slighty but dont delete it. if you delete it you will be left with a sharp edge at the entry to the AFM which is very bad
      • HennaE30
        • Apr 2014
        • 1965
        That is what I thought. Thank you guys.
        • ForcedFirebird
          • Feb 2007
          • 8300
          If you remove that, it will costs you 4-5whp. Leave it and the entire stock intake on for a stock-ish car. Dyno proven on a Spec e30.
          john@m20guru.com
          Links:
          • HennaE30
            • Apr 2014
            • 1965
            PO had a Spectre intake cone intake and it was horrible.
