Fuel line questions/confused
  • fresh_TD
    • Aug 2013
    • 2457
    So I replaced the steel fuel lines on my '87 325e and put everything back together..now the car won't start..I may have hooked the the rubber fuel line to the wrong steel lines?
    In this picture I colored the lines to help better understand what I'm trying to explain. The one in red is the hose that comes from the FUEL pressure regulator(this hose should hook up to the feed line correct?) The one colored in yellow coming out of that canister should hook up to the return line? And the one in blue hooks up to the last steel line? I dint even know what this last hose in blue is tbh....Thanks in advance
    Sent from my Samsung Note 3
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
  • jeffnhiscars
    • Jun 2011
    • 6011
    The fpr hose is your return line and the one from the canister handles vapors not fuel
    Alice the Time Capsule
    • fresh_TD
      • Aug 2013
      • 2457
      So the line in blue goes to feed line then?
      • Cabriolet
        • 9620
        blue line is feed. red line is return. yellow comes from gas tank to pressurize the system.
        Much wow
        I hate 4 doors
        • fresh_TD
          • Aug 2013
          • 2457
          Thanks....the car is running now..I had the lines switched...hope it's not going to cause issues because I tried starting the car with the lines hooked up wrong initially
          • DeckDub
            • Jul 2014
            • 61
            glad you posted this i was looking for some fuel hose routing info.
            it won't hurt your car to start it with them hooked up wrong, i did it before on my mk2 jetta and all was well.
            • fresh_TD
              • Aug 2013
              • 2457
              Yea no problem..the car is running fine now..started right up once I hooked up the lines correctly :-)..next time I'll make sure I label lines..lol
              • Cabriolet
                • 9620
                i saw that but forgot to mention. the top hard line is the high pressure.
                Much wow
                I hate 4 doors
