M20 clunking/knocking loudly on cold startup
  • thatphysicsguy
    • Mar 2013
    • 843
    Recently did the headgasket on my b25. I got the head cleaned and resurfaced. The machine shop also pressure tested it and it had no problems.
    After I got everything back together, I did a valve adjustment and fired her up. Still pretty noisy.
    Let it cool down for a while, did another valve adjustment, then turned it back on.
    So my question is: does having a clean head with less gunk floating around make the clicking noisier? should I keep trying to adjust those valves till it goes away? are there other problems that might cause this? from what I've read, sometimes the eccentrics get a notch worn in them, but that isn't the case here.
    Edit: after firing it up and letting it run warm a couple of times, I realized the sound isn't the usual valvetrain click, it's more of a clunking sound. It goes away once the engine warms up.
    '91 325i
  • 101
    • Jul 2011
    • 764
    I had the exact same issue with a newly built head so I'll share my dumb-ass mistake ...
    I had set the valves to 0.025 thousandths instead of 0.25mm (which is 0.010 thousandths). It sounded awful to say the least.
    Just something to double check.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • Ether-D
      • Sep 2011
      • 2838
      Timing belt a tooth off resulting in piston/valve contact? How much material did the machine shop remove? Were the depth-dimples still in the head?
      Where did you place the feeler gauge? The consensus says that you should put it between the cam and the inside of the rocker. Then set it to 0.007 (I did 0.20mm) because of rocker ratio. The reason to measure it there is because the eccentrics, over time can beat a depression into the top of the valve and the feeler when placed there bridges the gap giving an incorrect setting. -----> )l) <----- That's my best shot at a drawing of this phenomenon.
      I once replaced a head (w/junkyard head) and when I got it back on after rebuilding it, I had a ton of snap-snap-snaping when I would drive. I had ever so slightly bent a valve on the spring side while putting the cam (or rocker shaft) back in. So it would stick open then get forcibly shut by the piston. It was a pretty violent sound though. Probably not what's going on with you.
      On another note, the pulley spacer you made for me is still performing exactly as it was intended. Thanks again.
      Originally posted by Andy.B
      I was born on 3/25…
      • thatphysicsguy
        • Mar 2013
        • 843
        Thanks, glad it's working out well for you!
        The noise (more of a knocking actually now that I think about it) goes away when warm, so maybe it's no issue at all?
        '91 325i
        • dnguyen1963
          • Nov 2011
          • 2651
          What oil are you running in your car? Incorrect oil can cause a lot noise.
          • thatphysicsguy
            • Mar 2013
            • 843
            20w-50 castrol
            Oil isn't it
            Maybe it's just natural m20 noise? it is dramatic on cold startup, but goes away once warm. It's different than usual m20 valve click. A much deeper knocking sound
            '91 325i
            • my_bmw_sucks
              • Feb 2014
              • 16
              Having the exact same issue. Had my head rebuilt while doing a head gasket. Adjusted the valves on install; lots of noise. Adjusted again after 500 miles; still lots of noise. Going to give the cam/rocker method a try versus measuring at the eccentric.
              thatphysicsguy: if you figure out what your noise issue is please let us know.
              • Ether-D
                • Sep 2011
                • 2838
                I've heard that a nice fresh top end can finish off a well used bottom end. I don't know if there's any truth to it. Could it be rod-knock?
                I was born on 3/25…
                • AwakenNoMore
                  • Dec 2010
                  • 1291
                  you sure your not hearing injector tick?
                  1991 325i - "Scambles" The Daily Driven lightly modded.
                  1988 Mazda RX-7 TII "Mako" The Free Dorito
                  bacon by Jared Laabs, on Flickr
                  • Gary Yogurt
                    • Jul 2014
                    • 84
                    Yes, this. Stethoscope it to see if it's actually coming from under the valve cover. The injectors are loud.
                    Eternally searching for a nice set of BMW Sheepskin Seat Covers for Comfort Seats.
                    • thatphysicsguy
                      • Mar 2013
                      • 843
                      The noise goes away once the motor is warm (which is a good sign kinda) and is more of a clunking/knocking sound rather than valvetrain/injector click.
                      '91 325i
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        There is some science to this the idea being that the improved compression from a valve job adds too much stress to a worn bottom end. I have to say that an engine "clunk" is never normal so I wouldn't ignore it.
                        Alice the Time Capsule
                        • ADEN
                          • 620
                          Originally posted by thatphysicsguy
                          20w-50 castrol
                          Oil isn't it
                          Exactly what i have opened head twice and the sound is there even after engine rebuilt, it is been there for more than 8 years lol.
                          I think it is a rod/main bearing clearance issue since i changed the bearings twice during 8 years they always came badly worn, but even after new bearings sound is still there .
                          • digger
                            • Nov 2005
                            • 6194
                            Could be piston slap if it goes away when engine warms up
                            • thatphysicsguy
                              • Mar 2013
                              • 843
                              Hey Everyone, just checking back in for the sake of posterity on this. This was years ago that this happened and while I can't quite remember all the details, I think I eventually traced it back to either a loose pulley or the cooling fan slapping the radiator shroud. I ended up getting the motor mounts changed and rechecked the belts and everything was running smoothly from there.
                              '91 325i
